Old 02-03-2011, 11:51 AM
nytro2413 is on a distinguished road
My first build
ok so gonna start my first build. Ive modeled it in sketchup and was hoping to get some feedback from you guys. but itt wont let me upload the skp file. what should i do? thanks
Old 02-03-2011, 03:49 PM
robe_uk's Avatar
robe_uk is on a distinguished road
Export as jpeg picture or compress the file into a zip file and attach.
Rob
I'll get it finished sometime after I start it.....
Old 02-03-2011, 04:43 PM
here are some pics, but i made the sketchup file a zip and when i try to upload it says Upload of file failed anyone know why?
The top is a torsion box and the dimentions are 30" x 60". any feedback on design would be great thanks
ID:	125564   Click image for larger version
ID:	125566   Click image for larger version
ID:	125567   Click image for larger version
Old 02-03-2011, 05:20 PM
ger21's Avatar
The 3/4" gantry sides will have too much flex, and it looks like your Z axis/router mount could use some beefing up.
Old 02-03-2011, 05:27 PM
bobsch's Avatar
bobsch is on a distinguished road
If you're going to use casters make sure all four lock, both wheels and swivels like these http://www.grizzly.com/products/H0684. Otherwise you'll be chasing your machine all over your shop.
Bob
"Bad decisions make good stories."
Old 02-03-2011, 06:02 PM
lol yeah i just put those casters on there to show the idea, i plan on getting a system where the wheels will pivot up and stand on solid legs if not then the casters will have locks.
Old 02-03-2011, 06:25 PM
in my model the gantry sides 11 1/2" on the bottom. How much longer do you think i should make them? if i extended the side angle all the way ( pic below) will that be sufficent? And on the Z axis should i make the pieces higher to achev that? (pic below)
ID:	125575   Click image for larger version
Old 02-03-2011, 06:56 PM
ger21's Avatar
I'm saying the 3/4" thickness is the problem. They'll allow the gantry to flex from side to side.
As for the Z, yes, taller would probably be better. And you'll also probably want two clamps.
Old 02-03-2011, 07:16 PM
im not saying your thinking is off by no means but it seams like all the mdf machines i have seen have used 3/4 inch as gantry sides, maybe i havent done enough research. If thats the case, what if i added a layer of 1/2 mdf and made a
1-1/4 side gantry would that surfice? Yeah after looking at a bunch of other machines i have seen that the z axis is beefier, ill correct that. and will add another clamp, not quite sure why i didnt think of that in the begining.
Old 02-04-2011, 10:15 PM
ok here are a few changes, i put an angle on the gantry sides to try and counter the router weight a little (when i actually build the gantry ill do some balance tests and find the center of balance and adjust from there) and beefed up the z axis a little. comment away. thanks
ID:	125651   Click image for larger version
ID:	125652   Click image for larger version
ID:	125653   Click image for larger version
  #11   Ban this user!
Old 02-05-2011, 04:39 AM
CarveOne is on a distinguished road
Looks good with one exception. I would not recommend blocking the top of the router's air intake with the plate that projects outward over the router. Put a hole in it or cut it back so that it doesn't block air flow. The router needs maximum air flow to stay cool during hours of continuous running. The part that projects does not do anything for strength or stiffness anyway
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
  #12   Ban this user!
Old 02-05-2011, 08:25 AM
CarveOne
i think the picture wa a little decieving. The top mount dosen't go all the way back. ill give you a better angle, but i did move it down a bit because most routers do have ther cooling slots there. Thanks for the advice keep it coming.
ID:	125692   Click image for larger version
Build Log: RMGVideos XZero Raptor Build sagreen DIY-CNC Router Table Machines 150 05-10-2011 03:00 PM
Newbie - To build or not to build Router/Plasma Table dfranks CNC Plasma and Waterjet Machines 10 04-07-2011 11:16 PM
Joe's 4x4 hybrid build/2006 build krap101 DIY-CNC Router Table Machines 1 08-09-2010 05:30 AM
New Large Table Build in Houston, TX (Build Log) anitel Plasma, EDM and other similar machine Project Log 12 12-30-2008 02:45 AM
