Old 01-30-2011, 07:10 PM
adam_m is on a distinguished road
Rack and pinion spring force?
How do you determine the correct spring tension for a rack and pinion design similar to CNCRouterparts designs?
Is there a concern and detriment for using too much upward force from the pinion into the rack gear?
Thanks.
Adam,
Old 01-30-2011, 08:06 PM
wcarrothers1 is on a distinguished road
I never really could sort out what I considered a good hinge mechanism for the "spring" rack deal. So I just hard mount mine while keeping the alignment as precice as possiable.. Really don't see the point in having spring tension if you kept the tollerance between your linear rail and rack mount precice..
b.
Old 01-31-2011, 05:57 PM
b.
So your rack doesn't pivot then, it's a fixed distance from the rack? What about the chance of binding any worries about that?
Adam,
Old 01-31-2011, 06:52 PM
To me if things are aligned properly in the first place you should not have to worry about binding. My first machine was pretty low on the tollerance on the rack axis and still hard mounted bearing blocks and tension.. ..
First and second machine are hard mounted. Just wanted to say it's not always needed.
b.
Old 02-03-2011, 02:13 PM
Assuming I were to go with a tensioning system how would one determine the force required?
Adam,
Old 02-06-2011, 05:48 AM
I can't believe no one else has any ideas on how to determine spring force... thoughts, suggestions, ideas, anyone.???
Old 02-06-2011, 06:04 AM
ger21's Avatar
I'm pretty sure I've seen the formula posted here before. Try the google search.
Old 02-06-2011, 06:07 AM
ger21's Avatar
http://www.cnczone.com/forums/mechan...ar_forces.html
http://www.cnczone.com/forums/72304-post3.html
http://www.cnczone.com/forums/420226-post2.html
Old 02-09-2011, 05:57 AM
Thanks ger21 exactly what I was looking for except I might need a little help in digesting the information.
So, trying to understand the math and the application here...
From (http://www.cnczone.com/forums/72304-post3.html):
"3) The separating force for 20 degree components is .364 x the drive force applied. Thus if you need 100# drive force, the spring engagement force must be greater than 36.4# in order to keep the pinion engaged."
What determines the driving force that is required? Is that the force of the stepper or the maximum force required before slippage?
How does this apply to a NEMA 380 oz. stepper?
Adam,
Old 02-09-2011, 11:46 AM
moswald80 is on a distinguished road
I have been thinking about this lately as I am close to installing the R&P drives on my build. I am using the CNCRouterParts NEMA 23 drives and motors so the way I see it:
380 oz.-in. (motor torque) * 3:1 (reduction [belt from motor to pinion]) = 1140 oz.-in. (neglecting any losses from the belt drive)
1140 oz.-in. (pinion torque) / .5 in. (pinion pitch "radius" [half the pitch diameter]) = 2280 oz. = 142.5 lbs. driving force
142.5 lbs * .364 = 51.87 lbs. max separating force
This seems pretty high to me but it is the theoretical maximum and would likely only happen if the axis was run up against a hard stop with the motor trying to push through it. I would guess that half or less of that force would be required in normal practice. Does anyone have any experience with this?
Thanks,
Mickey
  #11   Ban this user!
Old 02-09-2011, 09:03 PM
Mickey,
So does that mean that a spring that has 51.87lbs. force keeps the pinion gear in constant pressure of the rack 100% of the time and would stall the motor before skipping a tooth?
Adam,
  #12   Ban this user!
Old 02-10-2011, 10:25 AM
Yes, I believe so.
Rack and pinion spring loading question microdot Mechanical Calculations/Engineering Design 0 11-12-2009 09:10 AM
Rack and Pinion Spring Tension System? dpaish CNC Plasma and Waterjet Machines 1 07-16-2009 01:17 AM
Spring loading rack and pinion? flash319 DIY-CNC Router Table Machines 4 03-17-2009 06:57 AM
spring loaded rack and pinion dgalaxy CNC Plasma and Waterjet Machines 4 12-03-2006 11:49 AM
Spring Loaded Rack and Pinion request ty1295 CNC Plasma and Waterjet Machines 1 02-07-2005 11:15 PM
