I need some help. I build a slightly enlarged JGRO type router. The machine works excellent except for one problem. If I try to cut something like a 3x3 square out of 3/4" mdf I keep getting left a stepped line one one side of the square. There is a step at each depth of pass. Each step extends out a little further than the last one. The other three sides are perfectly smooth. I initially thought it was maybe a backlash problem. I am using dumpster anti-backlash nuts on 1/2-10 acme rod. I checked backlash by putting a dial indicator on each axis, jogging it back and forth 1" and seeing if it went back to zero. It goes there every time. I also tried just jogging it .001 each way and it shows up as .001 on the indicator. My next thought was that maybe my spindle was out of square. I took a machinist square and held it up next to my bit and I can not see any gaps anywhere around the bit. I also thought maybe I was missing steps but I am running at a fairly slow feed rate (30ipm) and a very conservative depth of cut (.100) for mdf. That and the steps are repeatable if I cut out multiple parts. I am stumped at this point. Any suggestions? Keith |
| I expect you may find that the bit is tilted one direction. Slanted with the top towards the part on the side that is stepped. The opposite side gets cut off each time. R/
__________________ Mike Pensinger Chief Brewer, The River Company Restaurant & Brewery, Inc. Radford, VA |
| Problem- When you power up X and Y are not where you left them | Farmers Machine | CamSoft Products | 2 | 09-21-2009 05:56 AM |
| RFQ-5 left and 5 right | rbest27 | Employment Opportunity | 3 | 02-27-2009 07:49 PM |
| align left | kendo | EdgeCam | 2 | 11-19-2008 05:22 PM |
| Why do you use your left hand | ImanCarrot | General Metalwork Discussion | 24 | 10-15-2007 06:14 AM |
| Full Steps -vs- Micro Steps | DJB282000 | General Electronics Discussion | 10 | 12-28-2005 11:25 PM |
