Hey guys, I'm getting ready to design and build my second cnc router. The first one ended up being to weak and flimsy. For those of you that are new, here is the first machine... The 36" bars on the x axis are 3/4", not nearly strong enough. There is way too much deflection... The 24" bars on the y axis are 1/2". Definitely too wimpy. Most of the deflection comes from the Y axis. ![]() So here's the important part. I'm designing a new machine, and I really can't count on the first machine being too accurate. So I want to design a machine that can be built with the least amount of cnc parts, and still have a robust design. I'll attach a photo of the one that I am starting to design now. Yea, don't mind those slides, I still have to chop them to the right length. Anyways, the silver looking things are 80/20 extruded aluminum. I am using 1x2" extrusions in the design. The red parts are the only parts that I need to cut with my first machine. Probably plywood or MDF. Oh that gold colored thing in the middle? I'll probably buy a z axis from a guy on ebay!!! The green slides are igus w slides. Based on messages I saw in this forum, it was suggested that I use a single slide on each x axis rather than a double slide on each x axis. But I let my buddy at work look at my design, and he says it needs a double slide on each side. What do you guys think? ![]() Mike... |
| Couple of points; The Igus site has a lot of stuff to calculate loading, spacing and alignment. I asked similar questions of Igus tech and got these answers amongst others; Whatever rail you choose you will need much wider spacing on the bearings on each slide. These rails are not as forgiving as ball slides when it comes to racking miss-alignment. Single rails should do the X fine from a purely load capacity perspective. Single rails mean you have to mount each bearing individually with the accuracy required. Double rails would make the cost higher and require much more precise alignment. between rails. A benefit of a double rail each side is that the double rail comes with a mounting plate with the bearings already mounted on the carrage so taking care of some of the precision and probably giving a more ridgid gantry. These (igus W) bearings have significantly different load capacities in different load directions. Might want to consider that, for example the Y axis might be better with the rails on different planes. Andrew |
My buddy also thought it would rack in a sideways direction. In other words, if you stood in front of the x axis, and grabbed the top of the z axis and pulled it toward you... I don't see how, if the load capacity is there.
Mike... |
Thanks, Mike... |
| What he's saying is if you push on the side of the gantry uprights, the 3/4" MDF will flex and the gantry will move from side to side. By at least doubling them up, it will be stiffer. I'm making mine out of 2 pieces of 5/8 MDF, with a 1/2" Hardwood frame in between them. I also epoxied a 3/4" x 3/4" Aluminum tube running from top to bottom, in a rabbit down the center. You want them to resist flexing in all directions. Not sure how tall the uprights are, but I'd use 2 bearings on the bottom rail, about 12" from outside to outside. A single bearing will probably have binding or sticking issues.
For the second suggestion Ger has it nailed - you need to brace the gantry to avoid movement in twist. trapizoid and flex. Best way is to brace it in several planes. The Bearings are not structural and the bearings cannot be considered to carry any structural load.
Again the real reliable info is on the Igus web site an dthe design tools for Drylin W are very useful when planning this stuff. Andrew |
| Have you thought of putting a little extra into the existing router to "beef" it up? For example pull the 3/4" x rails and use them on the Y, and putting larger rails on the X. Or adding bearings on the bottom of the gantry running against a supported drill rod, or a flat piece of crs. There are probably a thousand other methods. While its an after thought, it at least makes this machine much more workable. Phil
__________________ Phil, Still too many interests, too many projects, and not enough time!!!!!!!! Vist my websites - http://pminmo.com & http://millpcbs.com |
| What is the cost of these compared to the thomson's or a thk style linear guide? I imagine they are less, but not by much. What I'm getting at is maybe since you are investing heavily in this machine, maybe aluminum would be a better choice for your framing system. Two 80/20 1530 sections and 10 square feet of 1/2" precision plate would not cost much, probably less than 125.00, and eliminate your flexing problems entirely with the same rails and a good design. Then youd have a machine more capabl that would last forever and take much more abuse, or use. Just something to think about.
__________________ Halfnutz (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#10
| I think you are about to repeat some of your issues with the previous machine. So I'd rethink the whole formulation. If you had stiffness problems before I don't see this frame helping alot. But then again I never understood the idea of placing guide rods under table. These should be close to the top of the table. Likewise I don't see alot of y axis support either. Thanks Dave |
#11
| Your original machine looks well built and only has problems with strength due to the small y-axis rods. I built a JGRO and I used 1.25" seamless shaft (very rigid) with skate bearings on my y-axis. You could use the 0.75" rails presently on your y-axis to strengthen your x-axis. If you improve the original machine it could accurately complete many projects for you. Jason |
#12
