Hello everyone. New guy here. In the planning stages for a router that will have a specific purpose. 95% of the cutting will be on 1/16" thick aircraft grade plywood. 5% 1/2" ply. 5% .020 aluminum. Router will be Bosch Colt PR20. Cutting area 24" X 72". The parts I'm cutting are very small and I'll need a very powerful vacuum hold down system. I have well equipped machine/welding shop. 30 years experience. Fabricating the unit won't be a big deal. I just need a few tips on sizing some of the components. I really like the simple design of the new Probotix FireBall Comet. It is a 25" wide unit, so I should be OK copying the gantry design. My unit will be 3 times longer, so the supported linear shafts and lead screws will need to be larger. Will 25mm Supported Linear Shaft be ample? What size lead screw? Motor size? I welcome your recommendations. ![]() |
| Craig, The supported linear rails are fine for this length, but using a screw for a 72" axis is asking for trouble. You will need a large screw to avoid whip, and at anything over 1/2", multiple start anti-backlash ACME nuts are not readily available at affordable prices. You could go ballscrew, but this is also going to be quite expensive. I would highly recommend going with rack and pinion drive for the long axis -- lots of others have done this with great success. Here's an article in our FAQ about R&P vs. ACME that might be of interest to you: CNCRouterParts Ahren CNCRouterParts |
Since vacuum holding strength is proportional to part size, small parts are very difficult to hold. You may find that you'll need to add tabs to keep the parts from moving, even with a very good vacuum. Exactly how small are the parts?
If you are only willing to give 105%, then those people out there giving 110% will out perform you! Just busting your (FIRE)balls. ![]() Randy
__________________ I may not be good.... But I am S L O W!! |
| why not consider dual drive R&P for the long axis, this will give you a clear space under for the vac and the long axis accuracy, have you looked at joes cnc?
__________________ James McGrew camaster x3, aspire software www.mcgrewwoodwork.com |
Here is example of smallest part: |
| It was late. I was tired. I'll try to give a little more in the future. |
#10
| Most designs look like yours. The rails are about the same height as the work surface, and the gantry is projected up from the rails, so the Z can project down from the gantry and reach the work. An alternative, which is how the FineLine Automation larger designs (FLA-300 for example) work is that the rails are just below the gantry, such that the bearing carriages bolt directly to the gantry beam and the work surface is suspended below the rails. This makes the gantry is much stiffer, because there are no vertical supports between the gantry and the rails. |
#11
I like the alternative method you describe better. Thanks. Here is where I'm at so far: Green frame - 1 1/2" square and 1 1/2" X 3" steel tubing. Purple members - 2" X 6" steel tubing (bolted to frame) Gantry - 2 pieces 3/4" X 8" aluminum Gantry sides - 7/8" aluminum plate Long axis rails - 1/4" X 2 1/2" 1018 cold finish steel Long axis carriages - CNC Router Parts Long axis R&P drive - CNC Router Parts Short axis rails - 1" linear shafts Short axis drive - 1/2" 5 start ACME Z axis rails - 5/8" linear shafts Z axis drive - 1/2" ACME Nema 34 steppers Last edited by BigSmith; 02-01-2011 at 06:04 AM. |
| New Build - Aluminum Router Table - 2' x 4' | wwendorf | DIY-CNC Router Table Machines | 15 | 05-05-2010 03:41 PM |
| Starting DIY CNC Router build - need advice! | rontruong | DIY-CNC Router Table Machines | 8 | 03-11-2010 11:18 PM |
| Newbie- Thinking of a CNC router build, advice please | janmclare | DIY-CNC Router Table Machines | 22 | 01-14-2010 09:47 AM |
| Need Help!- Need advice on router table build | jdcn05 | DIY-CNC Router Table Machines | 2 | 01-27-2008 04:02 PM |
| need to build a cnc router / mill for aluminum | axkiker | DIY-CNC Router Table Machines | 17 | 01-18-2008 10:32 PM |
