Old 01-29-2011, 03:44 PM
tpsimer is on a distinguished road
Lightbulb lathe spindle for cnc router
Good Afternoon,
I built a cnc router 5 years ago and it is running great. I now want to hook up a 4th axis to use as a wood lathe with live tooling. I found in my garage a 2hp treadmill motor. It is 130v dc variable speed.
I now have a couple of questions. What kind of board if any could I work with this to control the spindle speed from my computer? On and Off? Reverse and Forward? Could I use this motor with an encoder to control positioning for a 4th axis? What would I need to do this? If I cant control the positioning I know I would still need an encoder for the speed control. I would just hook it up to read the spindle. Any help or links would be appreciated. I expect to start to build soon and will post pics as they the project is completed.
tony
router vs spindle xspyke DIY-CNC Router Table Machines 7 03-19-2009 02:30 PM
Need Help!- Lathe spindle speed and lathe facilities GuntisK TurboCNC 4 10-26-2008 05:22 PM
Lathe spindle bearings and spindle material mackeym General Metal Working Machines 28 08-21-2007 02:49 PM
Lathe spindle bearings and spindle material mackeym Linear and Rotary Motion 1 08-11-2007 10:53 AM
UK router spindle? kong DIY-CNC Router Table Machines 14 08-25-2003 09:27 AM
