Old 01-27-2011, 08:26 PM
Bamball95 is on a distinguished road
Wiring question
Hey guys. So I need your expertise again I have three of these steppers 1.8DEG. 3.6V SIZE 23 STEPMOTOR-MPJA, Inc. and the hobbycnc EZ board. The steppers have 6 wires. Can someone please help me figure out how to wire these? The only information I could find didn't fit my board so I'm kind of lost. Also, is there a way to test if the wiring is correct? I haven't put the chips in my board yet.
Any responses are greatly appreciated!
Thanks, Beau
Old 01-27-2011, 10:07 PM
ger21's Avatar
Does this help?
http://www.circuitspecialists.com/pr.../57BYGH303.pdf
Old 01-27-2011, 10:29 PM
Thanks Gerry. I looked at that but the notation is different than the wiring suggested in my manual. At least thats what I think. Here is the manual. HobbyCNC Pro Manual scroll all the way down for the wiring info. They seem to use different lettering. It confuses me but maybe you, being a genius that you are, can figure it out haha.
Thanks a million, Beau
Old 01-28-2011, 01:50 AM
Gold Member
RomanLini is on a distinguished road
6-wire stepper can be tested easily if you have a ohm meter (multimeter).
They will be in 2 groups, and each group has 3 wires connected together.
Out of those 3 wires, one is the middle and the other 2 wires are the "phase" wires you need to control the stepper.
To find which is which, measure the ohms, there will be twice as many ohms between the 2 phase wires compared to the middle wire.
As another easy method for 6-wire motors, generally if there are 4 coloured wires and a black and white wire, the black and white are the middle wires.
If you are using the HobbyCNC stepper drivers then the 2 middle wires join together and go to power (motor power) and the 4 phase wires go to the 4 other pins.
Old 01-28-2011, 10:40 AM
Thank you! That helps a lot! This is probably a newbie question but does it matter if the pairs are switched? Like say the b and B wires are in the a and A terminals.
Thanks Beau
Old 01-28-2011, 10:48 AM
neilw20's Avatar
neilw20 is on a distinguished road
The motor might run the other direction.
Super X3. 3600rpm. Three ways to fix things: The right way, the other way, and maybe your way, which is possibly a faster wrong way.
Wiring question rs_customs PlasmaCam 2 05-12-2010 12:33 PM
Need Help!- WIRING QUESTION dcmetalwerks Phase Converters and VFD 4 06-14-2008 12:31 PM
New VF-2SS wiring question Matt@RFR Haas Mills 5 06-25-2007 04:10 PM
Wiring question TSJ Servo Motors and Drives 4 05-15-2007 01:20 PM
Wiring Question The Wizard General Electronics Discussion 17 01-04-2005 12:11 PM
