What will cause the direction of all three axis to reverse direction?? The machine and program will run fine all day but when I close out the program and come back the next day the now Pos (+) direction of all 3 axis are now Neg (-). I have to go into ports and pins to reverse direction and the next day it reverts back. I'm sure it's a simple thing but I have no idea. Any ideas out there?? Thanks |
| first check to make sure that you have administrative rights on the machine. If you change the directions and do not have the rights to copy the changes to the file, then, well... it wont. Right click on the c:\mach3 director left click on properties. See if the "READ ONLY" field is checked. If so uncheck it. After you fire it up and make sure its all moving the right way, click on config then go all the way down in the drop down box and click SAVE STETTINGS Close, re open and see if the changes stick. just a couple ideas |
| Motor reverses direction on its own from keyboard | BrassBuilder | Mach Software (ArtSoft software) | 4 | 09-23-2010 10:41 AM |
| (5 axis) Mach 3 not moving C B axis | hamooteh | Mach Software (ArtSoft software) | 12 | 03-22-2010 12:49 AM |
| Motor Reverses w/o Command | buz0340 | General Electronics Discussion | 24 | 03-25-2009 09:02 AM |
| Trying 1 Axis out with Mach 2 | Scra99tch | Stepper Motors and Drives | 1 | 02-13-2007 10:08 AM |
| will mach 2 or mach 3 work for 4 axis cnc? | Runner4404spd | Mach Mill | 3 | 10-05-2005 11:44 AM |
