Hello guys i'm a new in this forum i read Beginner Troubleshooting and Building Considerations and many others articles over the internet but that didn't answer my question...so i builld my first cnc table 3 feet by 5 feet but now i need to connected somehow to the computer. What will be good not to expensive, accurate around 1/32", USB kit so i can connect to the laptop with windows vista (board, small 3 stepping motors,power supply) working in 3 axis with easy to use software like autocad? ( something like draw and print) My cnc don't have to move fast because i will be cutting most of the time in 2 axis in wood and sometimes in aluminum but i wanna be able to cut in 3 axis sometimes. THANK you |
| You can draw your parts in Autocad. Then you need a CAM program to translate the drawing into G code. Search this site for recommendations. Vetric makes some lower cost software. Mach 3 will run the G code file and send commands out to your motors to move your machine. Typically you use the parallel port to do this along with a motor controller like the Geckodrive G540 (if it is appropriate for your motors - it might be overkill if they're small). However if you are dying for USB, you could use a smooth stepper for additional expense. Then you would go from that to the G540.
__________________ CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html |
| The "G Code" programming that Mach3 runs includes a FeedRate instruction, here is a tutorial on G Code: CNC G code Tutorial | Lumenlab |
| Need Help!- Loosing step more and more on X axis only after reducing the accl/velocity step motor | Calico | DIY-CNC Router Table Machines | 3 | 04-09-2010 07:23 PM |
| Need Help!- Step/Direction pins should be Step FWD and Step BACK | rayscott | Mach Software (ArtSoft software) | 6 | 02-09-2010 05:57 PM |
| Full step and half step hybrid driver? | rkremser | Stepper Motors and Drives | 4 | 11-20-2008 10:22 AM |
| Need Help!- How to edit MPFAN post file step by step | m_bhui | Post Processors for MC | 2 | 10-04-2008 05:42 AM |
| Step by step cnc plasma with parts list and links. | massajamesb | CNC Plasma and Waterjet Machines | 8 | 07-08-2007 10:22 PM |
