OK, I will power up for the first time in February. I have built a MechMate clone type machine with the MechMate rack and pinion. What are the maintenance requirements for the rack to last and run smooth? 1.Do you use a special lubricant? 2.What about spring pressure to engage the pinion into the rack, about how much pressure is correct? 3. How many hours of operation can I expect before the rack/pinion will need to be replaced? Thanks, Scott |
| I saw some information on the Mechmate site a while back. Regular grease or lithium grease on the rack. I believe I read somewhere that 12Kg (26Lbs or so) for rack spring pressure. It would likely depend on the leverage ratio of the drive mounts. I bought a few different springs, and will start low and move up if necessary. I have heard someone mention replacing the racks and pinions yearly under daily commercial use.....I really don't know myself as I'm just building my machine. I guess that would be about 1600 hours or so. |
| rack and rack & pinion with off the self planetary gearbox | eloid | DIY-CNC Router Table Machines | 4 | 12-06-2009 08:54 AM |
| New Machine Build- Rack & Pinion | captainkirk | DIY-CNC Router Table Machines | 2 | 06-27-2008 01:49 PM |
| Rack and pinion | TinkerDJ | Linear and Rotary Motion | 6 | 11-29-2005 11:42 PM |
| Rack and Pinion | Hillman | Linear and Rotary Motion | 1 | 08-09-2005 04:14 PM |
| calculatiing pinion size for rack and pinion setup | Apples | DIY-CNC Router Table Machines | 3 | 05-18-2004 09:36 PM |
