Old 01-21-2011, 12:27 PM
yury89 is on a distinguished road
Question on Travel Distance
Hello everyone,
Can anyone please tell me what is the recommended travel distance of x-y axis, of 3-axis mini/desktop CNC router, to machines a square 30cm x 30cm alumunium and 10cm thick?
Name:	CNC Router.PNG‎
Old 01-21-2011, 08:15 PM
jsheerin's Avatar
jsheerin is on a distinguished road
>30x30x10 + the diameter of the cutting bit you intend to use. Rails would have to be longer than those dimensions by the width of the carriages / bearings.
CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
Old 01-21-2011, 10:50 PM
So, will 1 meter length (total length, end-to-end) of both, linear guide rod and ball screw, would be enough for this small project?
Old 01-26-2011, 12:40 AM
LS120 is on a distinguished road
Talking X & Y sizes
i've found that depends on the materals you make it out of.. MDF or PLY you will need to add about 20cm each for X & Y for the carrages & Axis rails etc..
it also gives you a bit of wiggle room (clamps etc...).
so to do 30cm x 30cm i would do a 50cm x 50cm x 30cm machine at least or a 60cm x 60cm x 40cm to be safe..
just my 2c worth as i'm new & learning stuff all the time too.. and size is a major one.. i err on the too big then the not big enough.
Old 01-26-2011, 02:02 AM
Boomslang is on a distinguished road
Originally Posted by yury89 View Post
Hello everyone,
Is this the design you intend to use? Unsupported rails will not do the job.
Travel is not on exact distance FastFieros Fadal 3 11-03-2010 05:33 PM
Z Axis Travel Distance WarrenW DIY-CNC Router Table Machines 8 05-31-2010 06:57 PM
Mach 3 travel distance HELP! Please. CompositeCraft Mach Software (ArtSoft software) 1 09-25-2009 10:09 PM
Newbie- distance z axis can travel mostlund DIY-CNC Router Table Machines 7 12-14-2008 10:04 PM
Travel distance is inaccurate. thuffner3 TurboCNC 11 12-15-2004 08:32 AM
