The cheapest on Mcmaster in over $13 a foot! All they are is a molded plastic part that snaps together! There has got to be quite a mark up on them! But why?
__________________ Http://www.glenspeymillworks.com *Techno LC4896 - 2.2Kw Water Cooled Spindle | *Moving Table Mill from an Omis 3 CMM, 500Lb granite base, Hitachi router, Mach3 |
| One option is to build your own: DIY Cable Carrier LINK
__________________ http://paul-flores.com/ |
| A couple of cheaper variations is 2" non-metalic flexible conduit. Or even cheaper cable carrier sump pump hose!. Sump Pump Discharge Hose Kit, 1 1/4" x 24' # FP0012-6U by Pentair Water The down side is it is not so easy to add conductors after the fact, but very flexible. Al.
| $3 a foot sounds more reasonable for molded plastic pieces! But all the good suggestions everybody has given doesn't answer the main question- Why are cable carriers so expensive?
#10
There is no "printer ink mystery" and probably e-chain mystery. You need it, so they charge for it. With printers it is really quite simple. You just bought this new printer (really great deal, yea right!), installed the driver, discovered it's great attributes and it only works if you buy that one paticular ink cartrige. Do you really want to go through all that headache every time you find a better deal on ink? I think (they know) not! Misery Solved! Randy, edit: It was supposed to be "mistery solved", but misery is probably more accurate after all.
__________________ I may not be good.... But I am S L O W!! |
#12
| Pplug- Consider using flexible rubber hose, it has a number of advantages over e-chain and has been used to good effect in industry for over a hundred years. Rubber hose is; * cheap * quiet * no moving parts * no pinch points * no pivot points to wear out If you use a aluminium channel that the hose sits in it even has the self-guiding property of echain. That's how my machine is set up. Personally I just think people buy e-chain because they want their machine to look all space age ie "Transformers" like. |
| Flexible cable carriers | lamicron | CNC Plasma and Waterjet Machines | 19 | 01-13-2012 12:00 AM |
| Just IN- The wide world of cable carriers | igus | Product Announcements & Manufacturer News | 0 | 05-06-2010 12:35 PM |
| Cable carrier competition: The way you use your cable carriers could earn you a cash | igus | Product Announcements & Manufacturer News | 0 | 01-22-2010 12:06 PM |
| Cable Carriers for Plasma Cutters & More... | igus | Product Announcements & Manufacturer News | 0 | 08-26-2009 03:26 PM |
| Suppliers for wire carriers and Ball screw | ralbery | Want To Buy...Need help! | 0 | 01-27-2008 11:21 PM |
