Old 01-19-2011, 08:43 PM
HereinCS is on a distinguished road
Does bolting a THK rail to 8020 alum add rigidity?
Just curious, I plan to bold 2 THK sr25 rails to my 25 series 50100 extrusion. Does this add or take away rigidity to the beam? Thx.
Old 01-19-2011, 09:36 PM
cnctoolman is on a distinguished road
It should add to it. How much, I cannot say. But its like adding a stiffening rib or a brace.
Old 01-19-2011, 10:00 PM
dcb007 is on a distinguished road
With my machine it helped. I did mill a slight recess in the extrusion (somewhere around 0.05 deep) to seat the rail. You can see it on my site
You Can Build A Homemade DIY CNC Machine
and specifically this picture
http://www.neo7cnc.com/images/large/large014.jpg
In hind site I would have used 15 series 80/20 just to add to the rigidity but I don't have any issues with the 10 series I used.
Take care
Thanks,
David http://www.Neo7CNC.com
Old 01-19-2011, 10:27 PM
Thanks. Cool machine btw. I'm using 50100(basically 2" by 4") with a span of 48". Hope it's rigid enough.
Old 01-20-2011, 11:30 AM
giz giz is online now
giz is on a distinguished road
Yes, it will stiffen the beam. This is called a composite beam because of the dual materials.
What you are doing is basically adding cross-sectional area to the beam. But since this added area is made up of steel which has a higher Young's Modulus, you have to take this into account with what is called a transformation factor. This factor increases the width of your steel beam to give you an equivalent aluminum beam.
If your rail is 0.91" wide for example, you would multiply this by n=Esteel/Ealum and this would give you an equivalent aluminum width. I'm too lazy to look up the Modulus values for the rails and aluminum right now, but I imagine you are adding quite a bit of solid "equivalent aluminum" to your 50x100 extrusion.
More beam = more rigidity.
Old 01-20-2011, 12:17 PM
LeeWay's Avatar
LeeWay is on a distinguished road
You might consider bolting the rail to some steel first, then bolt that to the 80/20.
This is what I did on my lathe. It made a more solid base for them. The 80/20 rails are actually bumped up a bit around the tracks. When you tighten down on it though, it pulls whatever you are attaching down to the face of it. It might not be worth the effort to you, but that will also help with rigidity as well as give a more solid base for the rails should you need any shimming.
Lee
Old 01-20-2011, 12:47 PM
cliffy is on a distinguished road
Aluminium and steel don’t expand at the same rate,
bolt it nice and tight when it’s cold, then when it’s warm; it’ll be bent.
That is how a bimetal temperature sensor works.
BOLTING MACHINERY DOWN TO THE FLOOR?? iaknown General Metal Working Machines 17 10-06-2009 10:06 PM
bolting servo to ballscrew quest? integerspin General Metal Working Machines 6 03-03-2009 10:58 PM
Alum. Linear rail millman52 Linear and Rotary Motion 1 02-25-2009 09:00 AM
machine rigidity frankv Mechanical Calculations/Engineering Design 10 05-11-2005 07:30 AM
help - where to find 8020 t-slot alum landart DIY-CNC Router Table Machines 3 08-01-2003 08:45 AM
