| Cut some square blocks and measure the diagonals. Or, line them up against a straight edge, and check if the edges are aligned. Flip one over and see if it's still aligned.
| String from the middle of the opposite corners of the gantry to the rails I would check it from both ends. (An illustration for measuring a fence)Also, the 2-4-5 method. A triangle with the sides length 3, 4, and 5 will be a right angle.
__________________ My uncensored views and CNC Router planning: http://reinventingcnc.blogspot.com/ |
| I've got one of those 2 foot long painted steel carpenters squares, the cheap ones from the hardware store. It is surprisingly good, as good as my engineers squares! I think the big die they used to punch it out was cut on an expensive machine. ![]() And then I use Ger21's method, cut 2 squares as large as possible and flip one over. |
| is there an easy way to square a gantry? | 15mgtar | DIY-CNC Router Table Machines | 6 | 06-21-2010 12:40 PM |
| Squaring the gantry | bradbergemann | Excitech routers | 6 | 01-07-2010 07:31 AM |
| Squaring your Gantry, 1530 and similar. | Big S | Excitech routers | 8 | 04-15-2009 04:23 AM |
| Method to square a Gantry? | Motivator-1 | DIY-CNC Router Table Machines | 21 | 02-19-2007 07:30 PM |
| Can someone tlee me how to square me gantry? best way? | Apples | CNC Plasma and Waterjet Machines | 3 | 09-24-2005 08:30 PM |
