Old 01-16-2011, 12:43 PM
bagherdn is on a distinguished road
rigid router 2000*1100mm
hi
i'm working on 2000*1100mm
my aims:
1- precision: using hiwin rails and ballscrews and using some nice diy methods
for building
2- high rigidity: truss structre design and build with steel tubes which are filled with epoxy granit
i'm working on it more thane 18 months!
it is very like to madvac cnc on this thread: http://www.oneoceankayaks.com/madvac/madvac_index.htm
but has many differences, belive me
here is a pic of milling main structure for x rails and a fault on rail installation
nowadays i'm working on gantry and installation of ballscrews.
anyone interested can post me , i'll be glad for sharing infos
ID:	124035   Click image for larger version
Old 01-20-2011, 01:10 AM
rbjem's Avatar
rbjem is on a distinguished road
Definitely keep us posted on your progress. I am especially interested in the epoxy granite fill...
Old 01-20-2011, 11:11 AM
giz giz is online now
giz is on a distinguished road
Yes, more info on the fill would be great.
Old 01-21-2011, 12:25 PM
more info
yes, here must be more info so:
i have seen many peoples makes diy cncs from steel, aluminum, wood and mdf and.. not for metal cutting, so i decided to build almost allpurpose machine.
the first problem to do that we need a strong structure (many big guys use cast iron) and for a diy it means $$$$$$$$$$$
so i decided to make it simpler and cheaper (using steel tubes like madvac cnc) and have benefits of epoxy granit, the problem may be here is differenc of Thermal expansion between steel (12 10-6/K) and epoxy granit (9-18 10-6/K) but they can be equal by changing formula of epoxy granit .
so i filled main tubes of structure and gantry
Old 01-21-2011, 12:45 PM
rails accuracy & hand scrapping
one my biggest problem for my projects has been money! especially for machining this big one
at first i wanted to use metal epoxy for creating accurate surface for rails ( it means using set screws on the structure to make rails straight in two directione with help of steel tight wire, and injecting metal epoxy between rail and body) but it was so difficult , if you straight rail in one direction and then in other, the first one will be change
so i paid $ for milling X rail position, but the resultant was Horrible ! -+0.2 mm
therefor i used hand scraping method and get it -+0.05mm
Old 01-21-2011, 12:58 PM
Talking makint it with itself!
i've plenty of time & alittle $
so i made main body (with x rails) and gantry and then by installing a grinder i could do :
- making y rails position with accuracy copied of x rails
- nice cutting steel plates for future parts
- surface grinding steel plates
so i used it 4 iteslf
ID:	124491   Click image for larger version
Old 01-21-2011, 01:06 PM
motor driver
diy 3 axis stepper controller based on l297
out puts 4amp 12 volts
Old 04-12-2011, 01:57 PM
x axis completed
hi , slow progress but it is going on!
today i completed the x axis by installing ballscrew, I installed it as "one end fixed other end supported)
for this i used welding and epoxy binding. at first i installed temporary one end of ballscrew by screw
and installed the other end by help of gage to parallel with x rails and using lef-right set screws and two screw at under the end housing, then I welded first bearing housing (motor side)."pic start"
I pull gantry to nearest place to that housing and fix nut housing of ballscrew with epoxy (epoxy mix with iron powder that I collected from last part when I was grinding the y axis frame). "nut housing pic"
After becoming hard , Then I set the gantry at the end of machine (by turning the ballscrew) and put the other housing and fixed it with epoxy again. "end pic"
That was the process I used. More info on pics!
ID:	131385   Click image for larger version
ID:	131386   Click image for larger version
Name:	nut housing.jpg‎
ID:	131387   Click image for larger version
Name:	nut housing2.jpg‎
ID:	131389   Click image for larger version
Name:	nut housing 1.jpg‎
Old 04-12-2011, 02:32 PM
x motor mount discription
after being sure of installing ballscrew it was time to install the motor.
it is a 3.8v 4 amp unipolar step motor
for do that i used 4 steel bars as supporting legs and a mounting plate.
first i screwed the legs to the mounting plate (through the main structure) befor that i had put alittle place for setting the legs accuratly (be drilling bigger holes on the bearing housing) so it was able to set the four legs with an acceptable accuracy distance around the ballscrew axial then fix them with epoxy, then i installed the mounting plate again with bigger holdes than diameter of legs and with using a gage i set it with an accuracy about 0.08 mm radial and less than 1 degree in angular (by scrapping longer legs) and then fix it with epoxy ( what i would do if epoxy wasn't discovered or invented )
i used SRJ-40c coupling that needs radial accuracy 0.1 and angular 1 degree so not bad. i have forgatten to say that i used glass glow and alluminum sheet for sealing during casting epoxy resin .
result is in pics
ID:	131391   Click image for larger version
ID:	131392   Click image for larger version
ID:	131393   Click image for larger version
Old 04-29-2011, 10:51 AM
bad news
todays i am working on big problem with my machine!
it's WORKING TABLE is so weak and isn't stable and damp enogh
it's deformation (at center) with a 10kgs load is about 0.2mm
so decided to change it (again) to a truss structure and in future feel it with EG
i'll post the result soon
  #11   Ban this user!
Old 04-29-2011, 09:57 PM
Apples's Avatar
Apples is on a distinguished road
Machine will deflect even more when you apply a cutttng force.
My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
Can I rigid tap? sluggo Fanuc 15 02-08-2012 12:24 AM
What exactly is Rigid tapping? Why people always ask does it do rigid tapping? cjchands General Metalwork Discussion 23 12-19-2008 08:19 AM
rigid tap manuel2008 Mastercam 1 04-22-2008 09:10 PM
Rigid tap help. msteckhan Fadal 10 01-25-2008 07:12 AM
looking for 2x2 CNC router or plans for around $2000 sandman19792000 DIY-CNC Router Table Machines 8 04-03-2006 07:53 AM
