Hi, I have been reading and learning over the last year (On and Off) and I am finally beginning my build. This will actually be my second build, My first was from MDF and I was less than happy with the results. I have decided to build my machine from 8020 using cncrouterparts rack and pinion setup. I started getting the 8020 from ebay, and just recieved my 3x3 pieces with more arriving on tuesday. I just noticed that the 1.5x1.5 pieces were the light vesion and not heavy, Not sure what Im going to do about that, I will have to see what it is like when I get it in. I am including a picture of my planed setup, please let me know what you think. I am also planing on doing some 45's in the corners to stiffen it up. I am excited about this build and will share my experience as much as I can. |
beamsjr, You must really be excited about starting your build. Good luck. You know the drill! What size cutting area? What controller and motors? What spindle/router? Planning on using a "SuperPID"? Any & all design decisions made or under consideration are of great interest. I am also about to embark down the build path. Some decisions have been made others are yet TBD. What I know as of now: 3' x 4' cutting area. Mostly 80/20 base/frame. (may incorporate alum plate &/or MDF for gantry uprights, based on budget vs expense) R&P for the X & Y axis'. Acme for Z-Axis. CNCRouterparts carriages. G540 driver w/ appropriate motors. I'm still in the design/planning phase, but will be ordering parts soon and complete the design around parts aquired and budget. I'll be watching your progress intently. Good luck with your build. Remember to post lots of pic's! Randy,
__________________ I may not be good.... But I am S L O W!! |
| Hi Randy, The cutting area will be almost 3.5 x 4.5. I really dont need it that big, A lot of my design considerations came from what parts were available from cncrouterparts and would need the least amount of modification to work. For instance, I made my Y axis 60" because I can get the 4" x 60" rails. I currently have the Hobby CNC pro board with 4 axis and the Nema 23 305oz Motors. I am reusing them from my last build. I know most people are using Gecko drives, but the hobbyCNC setup is working really well for now. I may look into gecko's in the future if I blow up my HobbyCNC drive. I will post some pics of my controller setup in a bit. I also have a BOSH router I think the model is 1617EVS and a K2 mount that I will be reusing from my last build. I still have to track down the company that makes the precision collets for that router. I remember looking at them quite a while ago. I am sure at some point I will get a SuperPID, If I have enough cash towards the end of the build I may pick one up. I haven't read up on if they figured out the speed control from Mach 3 yet, If they have I just might take the plunge. Here is a link to a video of my old CNC, I had a ton of problems with it, mostly because all the parts were cut by hand and I could never get it to cut square. YouTube - beamsjr's Channel |
| beamsjr, Cool vid of your first build. It's a shame you didn't get the performance from it after all the hard work! However, it was a learning experience. I like the LCD on your control box. I'll have to consider including that option, if I can can fiqure out how to wire it in (electronics kind of baffles me ). Having no electronics experience I plan on opting for a more or less "plug & play" solution to the electronics.What do plan on using your machine for? Randy,
| I went ahead and put an order in this morning for some stuff I needed... 1 x 10 Foot Parallel Port Cable 4 x CNC Motor Cable Length 12 Foot 1 x Zero Backlash Helical Shaft Coupler 2 x Rack and Pinion Drive, Nema 23 - (I already have one) ---Pinion Gear Pitch 20 Pitch (Moore Gear) ---Pivot Standard ---Pulley 20 tooth with 1/4" bore (standard) 1 x 1/2" Shaft Collar 8 x Limit Switch 6 x Extended Linear Carriage with ABEC 7 Bearings and 2 Tapped Holes for R&P 1 x 1/2" Shaft Adapter 1 x 1/2" Needle Thrust Bearing and Washers Last edited by beamsjr; 01-16-2011 at 09:47 AM. |
Thats a difficult question, I am not really sure. Hopefully one day I will be able to make some side money with it, but until then I will be using it for everything from pcb routing to sign making, just as a hobbyist, for friends and family. If I get good at it and think I can move into the market I am definitely open to opening a business, but Im not getting my hopes up... I remember reading a post about who is making money using their CNC and the posts were rather disappointing. I have the bug though, and I wont be happy until I have my own machine. Unfortunately I had to sacrifice some of my loved woodworking equipment like my table saw to save up money for this, but hopefully in the end I will be more happy with the CNC. |
#10
| I am starting to get worried now that I have under designed my machine a little after seeing the 4x4 build of the fineline kit. It looks like it uses all 3x3 and 1.5x3 8020. I guess I will have to wait and see how strong it is when I get it together. The fineline kit also has 6 legs, Do you think this is really necessary or can I get away with the 4 legs as I had planed? |
#11
#12
I used two 6ft and one 12ft CNCRouterParts.com motor cables for few weeks. I then made custom cables with the resistors next to the G540 and found that my motors ran much cooler. Last edited by DonFrambach; 01-17-2011 at 03:31 PM. Reason: added link |
| Currently Active Users Viewing This Thread: 2 (1 members and 1 guests) | |
| bluesea |
| Yet Another 8020 CNC Build | jsantos | Open Source CNC Machine Designs | 203 | 04-29-2012 04:14 PM |
| New Machine Build- 8020 build 3x5 | sieg01 | CNC Wood Router Project Log | 30 | 03-17-2009 04:08 PM |
| Another 8020 build | Micky15044 | Open Source CNC Machine Designs | 7 | 08-16-2008 09:45 PM |
| New Machine Build- 8020 Aluminum Build | klick0 | CNC Wood Router Project Log | 21 | 07-09-2008 09:32 AM |
| 8020 BBR Router Build | ddbuster | DIY-CNC Router Table Machines | 3 | 07-09-2007 07:39 PM |
