| Ok i'm new to this & im havig problems with the size of some drawings i got. my table is 800mm (Y) x 1800mm (X) i've loaded some files in marc3 & they show in the Minus (-) and some 3-4 times my table size.. other things are what are the G-Code letters stand for?? x,y,z i know f = Feed rate ? L = M= (had m5 & m30) J = S = G1 = G3 = G53 = G80 = G49 = G90.1 = do i need these or can i edit the G-Code and remove them?? also my machine moves 421.4 units/min but the files when it cuts runs at 1.49 units/min. any help welcome.. thanks from NZ |
| L = Number of repeats in peck drill cycle M= (had m5 & m30) M5=stop spindle M30 program end rewind M3 start spindle J = part of G3 arc move see I J S = spindle speed G1 = move at set feed rate G0= move at rapid feed rate G3 = Counter clockwise Arc move G2=clockwise G53 = Move in absolute machine coordinates G80 = Cancel canned cycle IE: peck drill G49 = Apply positive tool length offset G90.1 =Absolute mode G91.1=distance mode If you look on the Mach screen next to the reset you'll see buttons for G-code & M code they will tell what each code does. |
| Also look at the manual for Mach3. I could not get a subroutine to work properly until I saw in the manual the the "Oxxxx" line can not have a number sequence on it. Took off the "Nxxxx" from the subroutine lines and all works well. |
| ok i've found out what they mean ![]() now ive set the f=20 & its ok but the router seems to be burning the dust, i'm using 4.75mm & a 3mm 2 flute bit to cut out the bits.. router is at max speed (28,000 rpm) it's a fuller (dermal type clone) any ideas? ![]() thanks for the help. |
| You need to go much faster, more like F1000-F2000. Or lower the rpm.
| BTW, if you're looking for help learning g-code, the G-Wizard Editor has a "Hints" view that decodes it to English: ![]() The beta test is free: GWizardE: A Machinist's CNC G-Code Editor Cheers, BW
__________________ Try G-Wizard Machinist's Calculator for free: http://www.cnccookbook.com/CCGWizard.html |
| ok got the new couplers & installed the one that broke... ![]() one question i have is with DXF files i load into Mach3 ? the dxf files i load seem to be in the minus of the Y like -59Y my table is from 0.0 x,y also the Y seems to be long like my X is Long & the x my Y is shorter.. how can i move , re do the drawing to only goto 0,0 & not into the - minus thanks |
| G-Code Help Needed | MetalShavings | G-Code Programing | 7 | 11-12-2010 03:42 PM |
| fanuc 6m g code help needed | beekeeper | Fanuc | 7 | 08-10-2010 07:04 AM |
| Source code needed! | GaryM | Visual Basic | 37 | 09-01-2007 11:38 AM |
| Help needed with G-Code | parts | G-Code Programing | 16 | 08-08-2006 08:23 AM |
| G code needed | patrickb | Fanuc | 3 | 05-27-2006 08:50 PM |
