Hi folks, After perhaps a hundred small projects i've killed my Kress FME 1050. The bearings collapsed and caused the motor to 'burn out'. bummer. I can't really justify another £160-£180 on another Kress as it hasn't really worked that hard. What are my options? I was considering butchering the Kress to remove the collet chuck so that i could then use it ( and the full set of collets i have for it) held in a relatively inexpensive variable speed wood router and when that router died, i could then just move it onto another one. Your comments/advice would be greatly appreciated. Regards, David |
| Hi David, Bit worried after reading this. I too have a Kress 1050, only used so far for around a dozen jobs so far but seems to be running healthy. Have you opened up the Kress yet? Any possibility of replacing the bearings or burnt out motor? Worse come to worse and your serious about your CNC'ing you could get a spindle, I was going to go that route but got a Kress instead because I couldnt justify the money on a small hobby machine but yea hopefully I dont regret that decision. Cheers, Josh |
| I would have to say that the Kress was used for only 250 - 300 hours max. cutting mostly acrylic and light ply. The bearings gave absolutely no sign of collapsing i.e no tightness or strange noise. Unfortunately, i have opened it up only to find a charred mess. The bearings could quite easily have been replaced. |
| Hi guys, I also have a 800 Kress, when I got it home I noticed that the bearings was quite tight and it was getting warm very fast, so I decided to try and run it in, first 10000 rpm 15 minutes, cool down and then start again, I did this many times then went on to something higher, today I still haven’t run it at full speed at a long time, it’s now not as tight and doesn’t get warm as much, I just hope it lasts so as to get my moneys worth. |
| Unfortunately i imported it from Germany about two years ago so i don't think i have much chance of getting anywhere under warranty. I have just bought a 2.2kW water cooled spindle from china so, if anybody in the UK wants to make me an offer for the six Kress collets i have....... |
#11
| Hi, I use a VFD powered chinese 2.2Kw water cooled spindle(2yrs now) and it's the best money I've spent. It's done hundreds of hours machining Ali 99% of the time and cutting some job's for 19-20hrs at a time and never get's more than warm. There's absolutly no sign of wear it makes the kress seem like a toy. It's super quite and accurate. 100% recommend one over a kress and well worth the extra it would cost. Buy the VFD in UK thou, chinese supplied vfd's are rubbish. Edit: Opp's didn't see post saying you had bought one, you wont regret it. |
| KRESS Spindle Motors | widgitmaster | Wood Working Tooling | 3 | 03-26-2010 07:33 PM |
| I think I killed it...lol | Pandinus | Hypertherm Plasma | 4 | 02-17-2010 04:44 PM |
| Killed a Mori today!!! | WOLOG | Mori lathes | 32 | 05-25-2009 09:34 AM |
| Kress Router Spindle Accuracy Question | gunlocators | Benchtop Machines | 2 | 11-08-2008 02:59 PM |
| Student wants to know if he killed his machine??? | MrG | General Metalwork Discussion | 6 | 12-23-2006 03:05 AM |
