Old 01-09-2011, 07:20 AM
jan4321 is on a distinguished road
Question small DIY CNC
I made a theard before but i posted it into the FAQ.
I am new at chczone and i want to build a small cnc.
here are some pictures:
The green things are rails. the blue things are NEMA17 steppers controlled by a tb6560.
The onerthings are made of wood and metal. The z Axis is not finished jet.
What do you think about this cnc? Do you have any suggestions?
Old 01-09-2011, 09:04 AM
bobsch's Avatar
bobsch is on a distinguished road
If you drive your x axis only from one side you will have a serious racking problem. Either move the x drive to the middle or drive it from both sides.
Bob
"Bad decisions make good stories."
Old 01-09-2011, 09:17 AM
yes, i think i can put the x axis to the bottom of the box and make a moving table. (the table is about the sice of an A4 paper)
like this:
Old 01-09-2011, 04:44 PM
awerby is on a distinguished road
If you're switching from a moving gantry to a fixed bridge design, you don't need those high walls to support your Y axis. Make your bridge more rigid with triangulated bracing; if it doesn't have to move it can be as heavy as needed. You'll need more length in the X rails to give yourself the ability to reach the far edges of your workpiece. I don't understand how the Z axis is supposed to work; are you planning to move it manually? NEMA 17 motors are too small; get NEMA 23s instead. In a machine as small as this, material costs won't be a big factor; I'd use metal instead of wood, except perhaps as a spoilboard on top of the table.
Andrew Werby
ComputerSculpture.com — Home Page for Discount Hardware & Software
Old 01-09-2011, 09:22 PM
RCaffin is on a distinguished road
Deflection problem
Either way the X and Y axes are OK, but the Z-axis has a real problem. The two rails on the y-axis are far to close together, and the tip of the Z-axis will deflect in the X direction.
Cheers
too small or too big? headsmess Taig Mills & Lathes 5 12-14-2010 07:30 PM
RFQ - Small Job - Small Holes dcg571 Employment Opportunity 3 11-29-2010 09:39 AM
Measuring small angles on small workpieces. skiingman Calibration & Measurement 1 04-01-2009 07:40 PM
Need Help!- Which small cnc mil cdfracing General Metal Working Machines 1 09-10-2008 06:06 PM
