Old 01-07-2011, 03:18 PM
kolias is on a distinguished road
My 2nd Machine in Progress
Approx cutting area 31”x48”, 4-280 oz-in motors, 4 independent drivers, cooling fan, BOB, 12V 29A power supply, 4 ACME 1/2-10 5 Start, V-groove ball bearings 1606-ZZ, Anti-Backlash nuts and double thrust bearings in all axes, LoveJoy couplings, X axis clears 7”, 8-LED lights under the cutter, Vacuum outlet, 110V Spindle or Bosch Colt, Control station for all electronics, Cable management. Waiting for the drivers & motors and should be completed approx. end of this month
Name:	New CNC1.JPG‎
ID:	123321   Click image for larger version
Name:	New CNC2.JPG‎
ID:	123322   Click image for larger version
Name:	New CNC3.JPG‎
ID:	123323   Click image for larger version
Name:	New CNC4.JPG‎
Name:	New CNC5.JPG‎
ID:	123325   Click image for larger version
Name:	New CNC6.JPG‎
Old 01-07-2011, 03:27 PM
My 2nd Machine in Progress, Part 2
Forgot to add the materials list. The total cost is about $400 less since I have items which I purchase for experimenting + some items which I buy in bulk
Name:	New CNC7.JPG‎
Old 01-07-2011, 03:31 PM
DIYaholic's Avatar
DIYaholic is on a distinguished road
Question Curious minds NEED to know!
kolias,
Nice looking build.
A few questions:
1) What drivers are you using?
2) What CAD/CAM program?
3) Will you be using Mach3 or something else?
4) Materials used, MDF, Baltic Birch Ply or OSB?
5) What will you be making with your machine?
Again, nice build. Looking forward to pic's & vid's of machine in action and projects made.
Randy,
I may not be good....
But I am S L O W!!
Old 01-07-2011, 07:06 PM
Thanks Randy, I must say I like my new build a lot
1) I’m using Keling motors 282 oz-in 8 wires unipolar. I had the same motors on my 1st build and I was very happy with them. I know unipolar is not very popular but I liked their performance.
2) I have Acad V14 but I also plan to buy the Vectric Cut3D
3) Yes I’m using Mach3, an excellent program once you get used to it
4) Most of the materials are 3/4" Plywood but in some places I used 1” Plywood (two 1/2" glued together. I also used a lot of aluminum for all motor supports, bearings etc.
5) I plan to make my own motor supports using 1/2" aluminum and do other machining with aluminum for friends. I also plan to do engraving and signs just for the fun of it.
It is a very exciting project and for sure I will post a video when she is ready
Old 01-08-2011, 02:17 PM
CNC Lurker's Avatar
CNC Lurker is on a distinguished road
That's an interesting idea you have for wire management on the back of the gantry.
What are you using in this pic:
Is that a plastic material like styrene or what?
http://paul-flores.com/
Old 01-08-2011, 03:44 PM
I got the idea from another member but I dont remember from where and I modify it to my needs. I used a 4" wide aluminum blind I had which I cut to 3" wide to fit in the space I have. To hold the cables together I cut pieces of cardboard about 1/2" wide by 3" long and screw each to the blind with two 4-40 x 3/4" long bolts. Works great but lots of work LOL
I will do the same on the Y axis
Old 02-13-2011, 03:04 PM
Here is the 1st dry run at 100"/min
YouTube - 2ND CNC First Dry RunA
Nicolas
Progress at last RustedOut Industrial Hobbies (Support forum) 25 10-16-2010 11:13 AM
My first CNC... in progress! hi-tech CNC Wood Router Project Log 12 06-02-2009 04:45 PM
Homemade machine update - a work in progress Chris D CNCzone Club House 22 01-14-2008 12:02 PM
MDF CNC Machine Progress victorbl CNC Wood Router Project Log 61 03-26-2006 09:39 PM
progress! (pix) anthony CNC Plasma and Waterjet Machines 12 06-03-2005 04:56 PM
