Great community in the zone. Soooo much to learn. So I get this crazy idea - build a CNC Machine in my basement! I don't know where to start asking for help, but I'll tell you where I am. I purchased parts piecemail on e-bay, (read enough but not enough to stop with plans "in my head".) Here's what I have: A welded steel frame and gantry of 2" square tube. Supported 16 mm rails in x and y, unsupported 16mm z 3 - 5mm pitch ballscrews and antibacklash nuts 260 oz steppers, TB6560 controller/driver Mach 3 Demo. motors are tuned correctly at 1/16th and I'm getting about 180 ipm Setup is very solid. Z slide is 1/4 plate aluminum. Mounted a cheapo harbor freight panel router for testing only. I can cut basic stuff in Mach 3 (circles and squares using the wizards or direct g-code.) This is where it ends.............now the hard work and questions. All help comments and referrals for counseling accepted! Given the above, is my 180 ipm a decent speed? I assume I have a rugged CNC for any wood or plastic. I'm hoping aluminum too? yes/no? (I am aware much becomes spindle and tool dependent and before I ever move to a serious spindle, I'll be mounting a porter cable 690) Current major heartaches - I have Rhino 4.0 CAD/CAM/ART - can't get the post processing files to open in the Demo version of Mach. I can export simple dxf stuff to Lazycam and load from there but thats not the long term solution. I havent installed my limit or home switches yet. Do these have to be installed and set for soft limits to work? Can't get those working I would really value your comments. THIS has been a great learning experience but I know I have .004 of the knowledge base I really need and want. |
Before I had home switches, I would jog up against the stops, and ref there.
Max must always be greater than Min. If you're getting an error, than your current position is either less than your Min, or more than your Max.
| Set as follows again for a 900x1000 mm table X max 950 x min -15 y max 850 y min -15 Z max 100 z min -15 I "think" I referenced home at 25 mm from the home min axis intersect point. I jog to mid table, hit the soft limit toggle switch and get,"machine out of limits for soft limit activation" I don't think I am properly setting or going to home now based on your earlier comments. After this last question, any basic book you could recommend for a rookie? May just look for a local class at technical school. |
| Evaluation Reached | brouser1 | SheetCam | 1 | 04-16-2010 12:21 PM |
| CAM evaluation input | rbach | General CAM Discussion | 0 | 11-24-2008 11:52 AM |
| Bobcad bobart evaluation help | becikeja | BobCad-Cam | 4 | 06-12-2007 05:33 PM |
| CNC Control Evaluation | Scott_bob | LinuxCNC (formerly EMC2) | 2 | 11-05-2005 05:33 PM |
| milling evaluation | hanz | General Metal Working Machines | 1 | 08-24-2004 11:44 AM |
