| The amount of backlash and misalignment compensation. Lovejoy type use various durometer rubber "spiders" between their hubs, and relieve axial and radial misalignment. Less backlash is achieved through the Oldham type with the tight tolerance plastic part which slides side to side to compensate for radial misalignment, not so much axial. The helical, whether bellows or spring type compensate both the best with no backlash, the shaft clamping being better than the set screw type. Jim |
| Lovejoy is a manufacturer, not a type, although prevalent usage has attributed spider couplings to them. Personally If you are using helical, I would use stainless, the aluminum does not take stress over time. I only use aluminum for encoder coupling. Suppliers such as Misumi, stock all types with the spider type coming with many different filler material. Their high torque servo disc couplers have zero backlash also. Al.
Is how they connect to the shaft. I've had bad luck with set-screw connections on couplers - and much better luck with the clamping type. They cost a little more, but save a lot in pulled-out hair... Andrew Werby ComputerSculpture.com — Home Page for Discount Hardware & Software |
| They can often be ordered that way, see if there is a Helical supplier in your area? Standard Coupling Guide Al.
#10
It's difficult to find them with different size bores at each end, especially when one is metric and the other one is Imperial. That's when you have to look more seriously at the Oldham type, which can be ordered as separate halves, or get boring... Andrew Werby ComputerSculpture.com — Home Page for Discount Hardware & Software |
#11
#12
| If you pick the required Torque range in the stainless models, and click further in it will allow further selection and give you minor and major bore dia, which can be ordered in Inch and mm combined bores and clamp screw types etc. http://heli-cal.com/cm/Products/Flex...MC-Series.html Al.
| Need NEMA 34 to NEMA 23 Adapter | jjackson | DIY-CNC Router Table Machines | 11 | 06-30-2010 08:48 PM |
| newbie questions on coupling, screws, nuts.... | fxs | Linear and Rotary Motion | 2 | 10-27-2009 09:31 PM |
| nema 34 1600 oz or nema 42 3200 oz? | 15mgtar | Stepper Motors and Drives | 3 | 07-27-2009 05:53 PM |
| New Machine Build- Rigid Coupling Vs. Flex Coupling | Johnsnd | DIY-CNC Router Table Machines | 10 | 05-30-2009 09:25 AM |
| Standard Nema 34's vs Nema 34's with encoder/controller. | SCCoupe | DIY-CNC Router Table Machines | 2 | 03-16-2006 10:03 AM |
