Old 01-01-2011, 02:24 PM
Jur1 is on a distinguished road
Question Aluminium extrusions plates tolerance stack up
Hi all,
my plan is to build and CNC machine from 8020 aluminium extrusions and aluminium plates.
I have a quick question about the aluminium plate tolerances. The extruded aluminium has tolerance of 0.008"(Thickness) is that to much for the following build or do I have a tolerance stack up problem? See picture 1
Aluminium Extrusions in Australia ghassall 80/20, TSLOTS and other Aluminum Framing Systems 1 01-10-2010 04:15 AM
Led light stack burned out on SL-10 Edster Haas Lathes 7 10-05-2007 06:27 PM
How do the linear slides stack up? jsage Linear and Rotary Motion 5 01-30-2007 04:57 PM
Triple stack NEMA 23? CharlieM Stepper Motors and Drives 2 12-22-2005 07:13 PM
