Old 12-29-2010, 08:27 AM
viscoelastic's Avatar
viscoelastic is on a distinguished road
oscillating tangential knife
Hi all,
I have seen other threads inquiring for construction of an oscillating tangential knife. I am lookinf for an off the shelf pre build one that I can adapt to the cnc table that we are building.
Thank You,
Old 01-04-2011, 09:08 AM
I hate to be a thread bumper, but is there really no off the shelf knife solution to build your own cnc cutter?
Old 01-04-2011, 03:07 PM
Al_The_Man's Avatar
What is your application?
Old 01-04-2011, 03:16 PM
Hi Al,
I will be cutting softer polyurethane foams. Kinda like the softness that would be in your coutch. Thicknesses from 0.250" to 1.500"
Old 01-04-2011, 03:44 PM
Al_The_Man's Avatar
I suspect that you may have a problem finding an add-on of this type, due to the requirement of integrating the rotating knife into the X,Y axis for interpolated moves.
I can see a table manufacturer building and designing the whole table with built in cutter head?
Even if a off the shelf add-on is available, it would require some integration it into an existing unknown system.
That would be my take, anyway.
Old 01-04-2011, 09:47 PM
wireb's Avatar
wireb is on a distinguished road
Have you though about a CNC hot wire instead of a osc saw?
Used hot wires for cutting hard foam before and I know you can get a "knife blade" version. You could just mount this on your cnc head and go to town. Eliminates the extra hardware needed to make the saw blade go back and forth.
Old 01-04-2011, 09:55 PM
wireb's Avatar
Forgot to add some links
Not sure if these guys would sell just the head or not but the do offer it for their machine for small cuts
COMAGRAV oscillating tangential knife
Another more DIY idea for thicker stuff would be to mount a jigsaw to your head and just let it run as the mill moves it around.
some folks are using a commercial handheld hobby ultrasonic knife as well.
Old 01-04-2011, 10:10 PM
We have a cnc continous band saw made by baumer http://www.baumerofamerica.com the problem is that it makes an entry and exit. We would like to be able to just plunge into a sheet and cut our drawn geometry. Good thought though, thanks.
Old 01-04-2011, 10:38 PM
wireb's Avatar
Some where out there I saw a hand held jig saw that you could steer the blade. Basically the blade was on a swivel that could rotate in the perpendicular direction of the blade movement. Wish I could remember what brand it was.
You could mount that do a plunge then steer the head based on what direction your moving in the foam.
I think the hot knife may be the simplest add on that would allow you to plunge and cut a shape.
Here is the Uline brand version
Foam Cutter, Hot Knife Foam Cutter in Stock - ULINE
4" cut depth and rated for soft foam (adjustable temp)
There are a ton of other vendors that make similar units with different size and shape blades
Just make sure you have good ventilation and don't leave it unattended when cutting.
Old 01-05-2011, 04:23 AM
Thank, I have seen the hot knifes. A few problems, one the fumes on polyurethane is toxic an second those won't cut the fabric laminated to it. Thanks though
Need Help!- anyone built a Tangential Knife Momentz DIY-CNC Router Table Machines 64 03-17-2012 12:03 PM
Tangential Knife Setup Help !!! Clax Mach Software (ArtSoft software) 0 11-11-2009 08:42 AM
support for tangential knife?? Matt McColley Mach Software (ArtSoft software) 3 02-25-2009 07:29 PM
to control tangential cutter w/oscillating avengine Machines running Mach Software 0 04-20-2006 10:23 AM
Add a tangential knife option avengine CNCzone Club House 3 04-13-2006 06:40 AM
