Yes, assuming you just want a strait ball end they are call ball end mills. Here is a 1/32" size one shars.com - Solid Carbide End Mill 132 4 Flute Uncoated DE Stub Ball I know shars stocks them down to 0.010" and up to figgen huge (1") Ball end mills are common so your favorite supplier should stock them as well. (just happened to have a shars catalog handy to look one up in) Or are you looking for a V bit with a rounded nose vs a point or flush tip? (start as diameter A tapers down at angle x to diameter B then the tip is rounded instead of a taper to 0 / cut flush) Not so sure about those best to ask the PCB folks. |
| I have a decent assortment of endmills for machining and for CNC router work, also a set specifically for PCB milling but nothing like I have described here. |
Closest thing I can think of is a Tapered ball nose or the custom 30deg ball end that Beckwith Decor sells, check it out here BDP - Cutters BDP 0,1 and 5 BDP5 is probably what you want. scroll down for the picture. Last edited by Phife; 12-23-2010 at 02:59 PM. |
| Are these what you're looking for? Tapered Ball End Mills : Bits & Bits |
| These are a little larger: Tapered carving tools for CarveWright & CompuCarve Machines |
| Just stumbled upon these. 2 NEW CONICAL 20 DEGREE TAPER BALL END MILLS HSS 1057 - eBay (item 380238574598 end time Dec-27-10 06:07:58 PST)
| Check out this page. Scroll until you see the bits. Check the bit number carefully. MLCS Dish Cutters, V-Groove, Sign Lettering, Router Letter Template Set, Sign Carving Jason |
#10
| You might try these also Solid Carbide Tapered End Mills 2 STRAIGHT FLUTES - BALL END Judleroy |
| Need Help!- Ball Screws | Sprint 77 | Want To Buy...Need help! | 3 | 04-13-2009 04:48 PM |
| Need help: Identify ball screw/ ball nut | RickOmatic | General Metal Working Machines | 0 | 04-12-2009 01:02 PM |
| Ball screws | the4thseal | General Metalwork Discussion | 7 | 08-21-2006 07:42 AM |
| Big Ball Screw & Ball Nut mistake. | Jack F | General Metal Working Machines | 12 | 04-28-2006 10:53 PM |
| Which Ball Screws to use? | Willyb | Linear and Rotary Motion | 4 | 01-19-2005 08:49 PM |
