Old 12-22-2010, 09:40 PM
hippy is on a distinguished road
hippy's cnc
Thought I would post some pics of my little 16x30 cnc router table and ask for some help the z axis.
Heres what I have so far.
My question is is there any small leadscrew close to the 10-24 all thread I'm currently thinking about using for the z axis? And does anybody have any idea how big the leadscrew nut is for something in the lines of 10-24?
I'm kind of limited in size which is the reason behind the 10-24 thread and nut
You can see the allthread in the first pic. It will work, but just how good is allthread to use?
ID:	121953   Click image for larger version
ID:	121954   Click image for larger version
ID:	121955   Click image for larger version
Old 12-22-2010, 09:50 PM
Wanted to add more pics if it helps.
I dont know much about the steel 1/2-10 nuts. Will they wear out faster than delrin?
I read somewhere not to use steel, but delrin. I plan on milling aluminum and brass, but made this for mainly wood routing and circuit board milling. I think for wood and circuit boards the steel is sufficient. Also is just using a spring loaded nuts satisfactory.
ID:	121958   Click image for larger version
ID:	121959   Click image for larger version
