Old 12-20-2010, 08:09 PM
gitarre10000 is on a distinguished road
Is the Gecko G540 the best for a beginner?
Or would this be better for a beginner?
4 Axis CNC Gecko G540 380 oz in Stepper Motor Kit - eBay (item 270571800913 end time Dec-25-10 20:40:25 PST)
THanks
Old 12-20-2010, 09:09 PM
Hyrum R is on a distinguished road
That kit you linked to is the same one that's sold at CNCRouterparts. I'm sure Ahren would actually appreciate it if you bought it directly from his website, as he wouldn't have to pay as much in feebay fees. (And it's cheaper on his website, too) Notice that his kit is using the Gecko G540. I and most everyone else agree it's the best for a beginner, and can even be the best choice for a production machine. It really is the best bang for your buck that I've ever seen. And it's virtually unkillable.
If you don't already have your motors and power supply, the kits that CNCRouterparts sells are a very good deal.
Old 12-20-2010, 09:29 PM
mlabruyere's Avatar
mlabruyere is on a distinguished road
The Kit you show the link for contains the G540 (a 4 axis Stepper Controller).....so I am not sure I understand your question.
You will need at least 3 steper motors, wires, and power supply. As noted Ahren sells all of these. You can also get great deals directly from Gecko for the G540 and their steppers.
Old 12-21-2010, 09:54 AM
DonFrambach is on a distinguished road
I just built a router with Steppers, cables, and Gecko 540 purchased from CNCRouterParts.com. (bought other stuff from him too) The steppers have connectors attached with proper resisters installed so it was a simple matter of plugging everything in and turning it on. Worked just fine from day one! That what I (a newbie) need. YMMV. Don
Old 12-21-2010, 11:03 AM
One minor thing to be aware of with the kits from CNCRouterparts is that the resistor is supposed to go right up by the drive, not on the motor end of the cable. But so far, no one has seemed to have any problems. I got a motor from him to play around with (and use on my next build), and I'm very pleased with its performance.
Old 12-21-2010, 01:45 PM
CNC Lurker's Avatar
CNC Lurker is on a distinguished road
THanks
If you're asking what would be the better route for a beginner, then the kit would probably be the better way to go. There are other kits available, such as the Probotix, Keling, etc., but I got the one in your link (also sold at Fine Line Automation).
You can see here how easy it is to wire it: Minimum wiring connections for Gecko G540 LINK
Gecko has a general wiring diagram, but the link above shows how to connect that exact kit. Since I'm a noob to this, I wanted a kit that was pretty much set up and ready to go.
Edit: Actually I got the 3 axis-kit, not the 4-axis kit in your link.
http://paul-flores.com/
Gecko G540 ?? gitarre10000 DIY-CNC Router Table Machines 18 11-23-2010 09:55 PM
Newbie- Gecko G540 Deb.bosch Stepper Motors and Drives 1 03-19-2010 08:40 PM
Gecko G540 Relay's Need Help The CNC Man DIY-CNC Router Table Machines 3 02-08-2010 05:16 PM
Need Help!- Gecko G540 rotger Servo Motors and Drives 0 06-02-2009 12:43 PM
gecko g540 Teyber12 Benchtop Machines 3 05-31-2009 02:23 PM
