Old 12-20-2010, 11:27 AM
wireb's Avatar
wireb is on a distinguished road
Spindle bearing source
Working on designing my high speed spindle and looking for a source for some 6x04-2rs (20mm ID is the only fixed dimension so far) bearings in the 25000rpm flavor.
What suppliers have folks used with good success?
So far I have checked mcmaster carr (21,000 max thin walled)
and found these on ebay
6004-2RS Premium Grade Bearing 20x42, 6004RS/C3, ABEC3+ - eBay (item 390250795708 end time Jan-08-11 16:05:54 PST)
according to the mfg they are 18,000RPM max.
They also stock a 6304-2rs just wating on a email back if the max speed is the same. (assuming the thicker the cross section the better for load and roundness)
Old 12-22-2010, 11:06 PM
RicknBeachcrest is on a distinguished road
Check out Boca Bearing. They carry lots of different types and sizes. I've bought lots of RC heli bearings from them. Good people to deal with.
Boca Bearing Company :: Ceramic Bearing Specialists
Old 12-23-2010, 03:37 PM
6204 is a deep groove ball bearing. Most spindle bearings are angular contact ball bearings or for slow(er) applications, taper roller bearings. This avoids the end play built into deep groove ball bearings.
ABEC 3 is not a very precise bearing for a spindle. Normally, ABEC 7 or 9's are used in spindles.
I guess it's a matter of "Precision costs money. How fussy are you?"
Dick Z
DZASTR
Old 12-23-2010, 05:23 PM
wireb's Avatar
Would prefer 7 or 9s but have been striking out finding anyone who carries 20mm ID in those classes.
Old 12-23-2010, 07:52 PM
ger21's Avatar
I think you need to go to ceramic to get to 25K rpm.
Maybe not.
http://www.vxb.com/page/bearings/PROD/Kit10829
http://www.vxb.com/page/bearings/PROD/Kit10871
Old 12-24-2010, 08:15 AM
wireb, Gerry is correct on the ceramic balls. You'd be really pushing the limits with the steel balls listed above.
btw, those are really good prices. We just bought (4) pairs of ABEC 7 15mm id sealed A/C bearings w/steel balls @ $369/pair.
Dick Z
DZASTR
Old 12-24-2010, 09:30 AM
ger21's Avatar
Typically, on a commercial Router Spindle, the ones rated to 18,000 use steel balls, and the ones rated to 24,000 use ceramic. That's why I mentioned that above.
Source for V bearing BUSHINGS (Eccentric, Concentric) mikemaat Linear and Rotary Motion 2 11-23-2010 09:05 PM
Ballscrew support bearing source fortyonethirty DIY-CNC Router Table Machines 3 09-21-2009 07:12 PM
r2c3 y-axis bearing source jamescrowe Bridgeport and Hardinge Mills 2 01-16-2009 01:54 AM
V-Groove Bearing Source needed widgitmaster Linear and Rotary Motion 20 03-31-2007 11:42 AM
Need a source for this bearing mount/assembly SteveL Linear and Rotary Motion 2 09-17-2006 07:43 PM
