  #229   Ban this user!
Old 02-21-2012, 07:19 AM
louieatienza is on a distinguished road
Originally Posted by neurofen View Post
to stop the beams from shifting as much as i can in the directions shown i'm going to use a few of these brackets. unfortunately they've got latches on both straight edges to fit to 90x45 extrusion so ill need to take 2 of them off on the side that will sit on the rectangular beam. theyre die cast, a hammer and chissel might do it otherwise ill get the angle grinder on em..
I got gussets for my build to do the same thing; though they were extruded; what brand extrusions did you use? I like the looks of those more; will have to add a cover plate to mine to dress them up...
  #230   Ban this user!
Old 02-21-2012, 07:47 AM
neurofen's Avatar
neurofen is on a distinguished road
45x90 bracket supplier
hi, i bought the brackets from kjn in the uk, friendly lot on the phone.....
http://www.aluminium-profile.co.uk/a...x90Bracket.pdf
they were about 4 pounds each and their extrusion's pretty good, i used 90x909L for the gantry and 45x90L for the y axis beams,
It's good to have the triangular brace on the brackets
  #231   Ban this user!
Old 02-21-2012, 08:09 AM
neurofen's Avatar
[QUOTE=morrnicar56;1070663]I also demoed SurfCAM. Very easy to use, excellent graphics and toolpaths. But at $10K, not including their high speed toolpaths, I had to pass. If I won the lottery it would be the CAM I buy. I shudder to think what their 5 axis package costs.
expensive stuff isn't it.... :
  #232   Ban this user!
Old 02-21-2012, 02:37 PM
These are the ones I got from Misumi, they're pretty beefy but the design os pretty utilitarian...
  #233   Ban this user!
Old 02-22-2012, 07:45 AM
neurofen's Avatar
they look alright, surely no need to change them, how much were they?
  #234   Ban this user!
Old 02-22-2012, 01:41 PM
The odd thing is, they accept a self-tapping screw for a cover plate, but there's none on the website. Still can't figure it out, will have to make my own I guess. I paid $20 each, which includes the screws and t-nuts. But since all the other screws and nuts I have are stainless, I swapped the screws out...
  #235   Ban this user!
Old 02-23-2012, 10:45 AM
neurofen's Avatar
is this your first cnc?
  #236   Ban this user!
Old 02-23-2012, 10:57 AM
Actually this is number 4. The first was just threaded rod and sash bearings to see how the electonics work. The second was my Solsylva build. Third is my current machine (with busted drivevr board!)
Second: http://www.cnczone.com/forums/diy-cn...lva_plans.html
Third: http://www.cnczone.com/forums/diy-cn...d_another.html
Current: http://www.cnczone.com/forums/diy-cn...ll_router.html
  #237   Ban this user!
Old 02-23-2012, 01:38 PM
neurofen's Avatar
you got the bug, its good stuff isnt it, cant wait to get this one into a workshop and watch the swarf flying :.. i just ordered a few more brackets and went with the 90x90, theyre only a couple of quid more than the 45x90's and will do a better job..
http://www.aluminium-profile.co.uk/a...x90bracket.pdf
just received a sample of a 2 part, CATALYSED epoxy ink which im hoping will be good for colouring engravings.
Name:	2 part catalysed epoxy ink.jpg‎
  #238   Ban this user!
Old 02-24-2012, 03:49 PM
neurofen's Avatar
[QUOTE=louieatienza;1072020] Third is my current machine (with busted drivevr board!)
how are you finding the belt drive for the y axis? just noticed you've got one motor in the middle driving both ends of the gantry?
  #239   Ban this user!
Old 02-24-2012, 05:29 PM
[quote=neurofen;1072791]
I find it works well.. Heck, aside from the table, I cut all the aluminum parts for my next CNC with it! Just upgraded to GeckoDrive, the link to the rapids test is in my build thread...
  #240   Ban this user!
Old 02-25-2012, 08:51 AM
neurofen's Avatar
DTI, new brackets and alignment
my DTI arrived today and the brackets for the base so i can finally get on with aligning it..., took me 20minuets to work out how to attach the DTI to the universal arm : ???got to watch those late nights
ID:	153696   Click image for larger version
ID:	153697   Click image for larger version
Tags
linear rail
Currently Active Users Viewing This Thread: 3 (2 members and 1 guests)
cgosselin, ‎Relu
New CNC machine build (big pics) ckm Vertical Mill, Lathe Project Log 15 04-30-2012 05:49 PM
My first build log of my belt drive DIY CNC Machine - PICs studysession DIY-CNC Router Table Machines 16 03-23-2012 11:10 AM
Schematic Diagrams/Block Diagrams of Fanuc Modules leor Fanuc 1 10-23-2009 10:14 PM
Newbie- Converting pics/diagrams to machine code nearbeer DIY-CNC Router Table Machines 2 09-01-2009 08:02 AM
Can I Build A Cnc Table Out Of These Parts?? Pics douglasco Open Source CNC Machine Designs 12 11-03-2008 05:34 PM
