Old 12-13-2010, 06:10 PM
tws tws is offline
tws is on a distinguished road
sign software/cnc
is it possible too configer vinyl master pro sign software
to run a cnc machine?
vpm has a lest of machine to choose from.
is there a machine in the lest that will emulate a cnc or an
engraver?
Old 12-13-2010, 06:14 PM
trevis1st is on a distinguished road
Which version of the software are you using? I think the newer version can make G-code for a machine. But I don't think it will work as a controller software.
Old 12-13-2010, 06:22 PM
tws tws is offline
i am using the old 2.50
Old 12-13-2010, 06:38 PM
You can probably generate the hpgl, dmpl, or gpgl code and edit it to work. You might even be able to get the post processor in VM to do that for you. Most plotters, that I know of, has a brain. So all you do is dump the file to the plotter and it starts cutting. Do you have a cnc machine and what are you using for it's brain(software)? Also what do you hope to be able to make?
Old 12-13-2010, 07:07 PM
tws tws is offline
i have no software.
thats why i would like to run
it from my sign program if i can.
my cnc is a home made one.
Old 12-13-2010, 07:47 PM
tws tws is offline
sorry i misunderstood the question.
i do have a control box from robotix.
Old 12-13-2010, 08:01 PM
You'll have to edit the Z and all the feed rates as well as some other things in each file. It can be done. It usually doesn't take long to get tired of that. Cut2D or CamBam would be good place to start without spending thousands.
Also there is dxf2gcode that's free.
Old 12-16-2010, 12:08 AM
tjskcnc is on a distinguished road
Check out this website for free programs and training:
cnc4free.org homepage
If you are serious about sign work, Vectric's V-Varve Pro is the way to go. More time sign making and less time learning software.
Old 12-16-2010, 03:17 PM
tws tws is offline
vpm-cnc
of all the plotters in the lest
witch one would be the easiest to modify?
V Carve Sign Software KnotsAboutWood General Signmaking Topics 2 05-18-2010 03:35 AM
Need Help!- Sign making software? jeffmorris General CAM Discussion 16 04-02-2008 10:33 AM
sign folks and their software? Crushmonkey General CNC (Mill and Lathe) Control Software (NC) 0 05-21-2005 02:57 AM
Software for sign making? CRFultz General CNC (Mill and Lathe) Control Software (NC) 5 04-12-2005 10:25 AM
