Hello Everyone, I have been kicking around some ideas for a new cnc mill. I have previously build cnc router mostly from 8020 and am pretty happy with it. It was a budget machine, but it has been a great help to my projects. I have since build two reprap 3d printers. One day while helping a professor clean out a lab, I came across four pieces of supported rail and eight linear ball bearings. He let me have them for free. So I have been wanting to build a second machine using those parts. I have been thinking about various designs for a long time now, and in the past two days was inspired by DonFrambach build.Here is a link Anyway, today I spent about 2 hours throwing together this 3d model. It is still raw, but shows the basic idea. I have not put all the bolt holes, nuts, or even lead screws or motors in. But I think there is plenty to get a good idea for what I am going for. I am stopping for the night and thought I would share what I had and get your opinions. Things to note: *I plan to use ball screws and stepper motors for the x and y axis. *Z uses precision acme lead screws. Currently 3/4" - 16. It does not need to travel as fast as the other axis and will be lifting more weight, so I thought gearing it up would be good. Also I need two and I thought ball screws wouldn't add enough for the added cost. *The y axis moves up and down as a whole. I like this design because I can clear higher objects. I have not seen another machine like this. I also think it will be more study. I would love comments about this design method. *There will be wear plates on the ends of the y axis. 8020 sells UHMW pads that match the grooves in the 8020. I have not added these to the model yet. Thank your for any comments. Josh ![]() ![]() ![]() |
| Similar to mine I am using spare parts from my 8 foot by 4 foot aluminum mill (I had enough extrusions left over) so i made it with parts on hand except a few off eBay here and there! And I cloned it from this persons build so the credit is his ![]() http://www.cnczone.com/forums/diy-cn...ter_build.html |
| You will also get more stable precision, through the entire Z-axis motion, having your Y-axis move up/down like that. The constant distance from the rigid structure is where you will gain that precision. (The end of the tool is always a fixed distance from the Z-axis, unlike one that slides the tool only, up/down on a floating-tray.) I would have done a similar setup, but I did not have enough money for the more complex setup. Perhaps my second machine will use a raising-gantry Z-axis. Looks solid as a rock... I assume it will be a tooling mill, for metals, or a precision etcher?
__________________ "There are no mistakes in DIY, only oversights that need adjustments." "I don't care, I don't follow standards" |
| Thanks for the comments guys. Here are some updated images. It is still a ways from being complete, but some of the details are starting to come together. The second image is the z-axis by itself. I am still working on the bearing aspect of the z axis, so far I am thinking of using some UHMW pads that would run on the inside of the vertical uprights. I am not sure if this will be enough or if I should add something to ride on the outsides as well. I am getting a little nervous about the cost of this machine. Hopefully by keeping my eyes open on ebay I can get some good deals. ![]() |
| The Y axis moving up and down is a good idea but depends on what type of parts you are doing. For example if you want to profile a part from a plane stock(let's say an aluminum plate) fixed with vacuum or in a vice , your design is great, having more precision and rigidity then a "classic z axis". But if you are making complex 3D parts , use different type of clamps and fixtures it's very likely that your y axis is going to collide, with the fixture or the part. The geometry of the part dictates the way you chose the machine axis distribution, there isn't a "best way", each configuration has it's strong points but also it's week points. For general use i recommend a "classic z axis" with the spindle connected to the z axis plate throw a part build as much as possible on the "equal resistance principle". This way you obtain a minimum z axis footprint. There are many things to discus on this subject. Best regards, Catalin (Sorry for my bad English) |
| So just a little update. Out of curiosity I had Nook Industries send me a quote for two 16" ball screw assemblies. $1,276.68 each. I about fell out of my chair laughing when I saw the price. I have worked with Nook before and they make great products. But I know for sure that I will be finding something else. Ebay or some refurbished parts. Worst case I will put precision acme thread on it for a while until I find some good ball screws. |
| The precision class of the ball screw has a major influence on it's price. On the market you can find C7 rolled ball screws at much lower price(they insure a 50micron maximum tolerance over 300mm, and some models have anti backlash nut ) |
| New Machine Build- Fixed gantry machine, my own take. | prcdslnc13 | DIY-CNC Router Table Machines | 25 | 02-14-2012 12:30 PM |
| fixed gantry | eloid | DIY-CNC Router Table Machines | 2 | 01-29-2009 04:20 PM |
| Build Thread- Fixed Gantry Machine | solodex2151 | DIY-CNC Router Table Machines | 8 | 09-04-2008 05:17 PM |
| Moving or fixed Gantry ?? | xairflyer | DIY-CNC Router Table Machines | 4 | 02-21-2005 10:54 AM |
| Fixed Gantry | Auzze | DIY-CNC Router Table Machines | 1 | 07-25-2004 02:34 AM |
