Old 12-09-2010, 01:48 PM
Stubby1 is on a distinguished road
Limited switch tripped no indication Mach 3
Howdy
A new problem cropped up and I can not seem to track it down. I have a limited switch trip warning, which stops the machine, but I can not seem to find the problem. Mach 3 is not showing which switch is tripping and it only seems to trip when the tool is in contact with the material. I have checked all wiring for exposed wires and loose connections.
Any suggestions?
John
Old 12-09-2010, 02:00 PM
DonFrambach is on a distinguished road
If your switches are connected to different inputs, I would disable all but one switch until I found the offending one. Then I'd look for a bad connection in or to that switch.
If, like me, you connected all your switches to one input, I'd short across several switches until I found the offending circuit. I'd then short across switches in that circuit until I found the bad one. Actually I did this just recently to discover that I had made a poor connection in one of my cables.
Hope that helps.
Old 12-09-2010, 02:03 PM
Another thought. There's a diagnostic screen in Mach3 which shows the status of all your switches. I'm not at my mach computer now so I can't tell you exactly where it is but I think its selected from the last tab on the right. That screen would tell you which switch Mach 3 thinks is tripping.
Old 12-09-2010, 04:43 PM
ger21's Avatar
Most likely your getting noise on the switch lines, Try increasing the debounce setting in general config to 2000-5000.
Old 12-09-2010, 07:30 PM
johnmac's Avatar
johnmac is on a distinguished road
Try what ger21 said first.
John
DESKCNC resetting mill table after limit switch is tripped Eclectic tool DeskCNC Controller Board 3 07-29-2009 03:40 PM
Mach 3 limit switch troubles?? jarr88 Mach Mill 5 08-06-2008 08:54 PM
Denford Limited UK Bradders Product Announcements & Manufacturer News 0 04-10-2008 06:14 AM
Start Switch Input to run Mach Setup HELP! PLEASE jimmychand Mach Software (ArtSoft software) 12 12-01-2007 07:05 PM
INCREDIBLE Forum...but why no Link-Visited Indication? polyNuker Forum Questions or Problems 1 01-09-2007 07:44 PM
