Old 07-08-2005, 11:33 AM
GalaticDan is on a distinguished road
Servo motor as spindle??
Hi. Has anyone managed to convert a servo motor's keyed shaft into a collet chuck?
Any suggestions would be welcome, basically searched the web for ages now and have not found NEMA56C bolt on collet chuck. I'm using an Allen Brad. F4075 servo motor.
Cheers
GalaticDan
Old 07-08-2005, 01:27 PM
acondit's Avatar
acondit is on a distinguished road
Servo Driven Spindle?
Why not just use the servo motor to drive a separate spindle?
Then if the servo motor goes bad you don't lose your spindle as well.
Look at "http://cnczone.com/forums/showthread.php?t=10695" and think about the possibilities.
Peace,
Alan
Old 07-09-2005, 01:04 AM
wizard is on a distinguished road
For most servo motors conversion of the shaft to a collet chuck would be difficult. Often shaft extensions are used for light duty work in industry. The issue here is that you end up with an extended load on the shaft to do serious machining.
A possible alternaitve is to take a servo motor and rebuild it with a new shaft and end bell. Not easy but can leave you with a very nice spindle. The issue here though is that many of todays servo motors do not have removable magnet or rotor assemblies. If you can get the speed range out of a 3 phase motor, you need, this may be the way to go. Three phase motors are oftne altered this way in industry.
One thing to understand though is that making a spindle is a non-trivial pursuit.
thanks
Dave
Cheers
GalaticDan
Old 07-11-2005, 12:17 AM
Moderator
MikeAber is on a distinguished road
This may be interesting.
http://www.cnczone.com/gallery/showgallery.php?cat=9014
Diy Spindle Motor Controler miljnor General Electronics Discussion 162 11-06-2009 10:01 AM
Using surplus servo motors as spindle drive Swede Servo Motors and Drives 11 03-16-2008 08:05 AM
how would this be for a spindle motor justin_sane420 Mechanical Calculations/Engineering Design 3 06-15-2005 12:34 PM
Spindle motor TommyB DIY-CNC Router Table Machines 1 12-08-2004 10:11 AM
Spindle power by servo motor Stevie General Metal Working Machines 4 04-18-2004 02:20 PM
