I have a very small shop which would limted the size of a CNC that I could build to likely 2' x 4'. However, if the CNC router were to be configured vertically I could consider a larger bed. I have been looking at some of the Fine Line Automation designs/kits - and starting to think about how these could be modified to run vertically. In a vertical orientation, the entire z-axis mechanism needs to be pulled against gravity. Would this likely require a stronger stepper? etc? What other issues come to mind for a router in this config? I'm new to CNC (first post) so don't blast too hard if this is a daft idea. |
| I'm going to build one one of these days that's not exactly vertical, but tilted at an angle like the panel cutting machines at places like Lowes and Home Depot. Just to gain space in my router room enclosure.... It's a good sized room, but I could use a couple more machines set up in there. The way I look at whether or not it will work well is, I imagine if I were to turn the thing upside down and shake it, would anything rattle too badly. So building it with well fitting parts can solve that problem. I'm 100% sure it'll work just fine. Only thing stalling me on it is time... ![]() I think I saw one done like that once, but don't recall where ![]() John |
| Here's a commercial vertical router: http://www.denfordata.com/pdfs/produ...cal-router.pdf |
| One of the big benefits I see is for cutting aluminium, large heavy chips that are impossible to vacuum up (especially with any coolant on them) will just fall down completely away from the cutting area. My design spec so far is about a 18" x 24" cutting area (portrait), 60' tilt, capable of mist/spray/flood coolant, and if possible maybe even 2 spindles. It would still be desktop sized but would be one heck of a capable machine, expecially for production of aluminium parts. |
| You counter-balance, and the motor and gantry become weightless. (However, momentum doubles, which places a slightly greater load on stopping-power, but not holding-power.) It is possible, and can be made manageable without a vac-system. Mounting holes and braces work fine vertical or horizontal. (You may still want to have a slight incline/tilt.)
__________________ "There are no mistakes in DIY, only oversights that need adjustments." "I don't care, I don't follow standards" |
#10
#11
Thanks. |
#12
| The trouble with just having the head moving vertically is that if you use a counterbalance for the head, it is all on the moving gantry. Also one of your full length bearings in along the bottom of the machine to get snagged or kicked or full of chips. That still might be best for a large machine. For a small amchine (like I want) I prefer the idea of the whole gantry moving vertically, it's more weight to counterbalance but easier to do. And it means both your main bearings run up the sides of the machine so the bottom is free for chips/coolant etc to fall down. |
| Vertical Mills | charper | Knee Vertical Mills | 7 | 02-20-2011 07:17 AM |
| Vertical Text - M8 | Swemill | Mastercam | 3 | 10-01-2010 03:13 PM |
| Go-Well vertical mill | Matt130 | Benchtop Machines | 0 | 08-14-2008 02:09 PM |
| Vertical Integration | Celling It | General Metal Working Machines | 5 | 01-23-2008 09:30 PM |
| where to buy these vertical clamps? | slow_rider | General Metal Working Machines | 4 | 10-11-2006 07:22 PM |
