Old 11-17-2010, 01:04 PM
shnitzel is on a distinguished road
vane vs vac??
im about to upgrade my vacuum table from just a mere 5hp shop vac...
im considering either the lighthouse brand vacuum pumps like here:
117123-13
240 volt
ShopBot Vacuum Motors
and have also been considering this rotary vane style pump here:
model 1100
Vacuum system table Air blower pump holddown CNC Router Canada USA
i cant find much info on the motiontek vane pump. it is about 3X the $$$ of the lighthouse pumps. they look to run about the same cfm... so for the difference in price do i get a way higher vacuum reading???
just looking for a few thoughts. i am holding full sheets of plywood down and cutting into various shapes. sometimes quite small. 6".. and i never seem to cut the same project twice.
i would run 2 of whatever i choose. as i am limited to about 15 amps at 240v.
is the vane style pump worth the extra dough$$??? does anyone have any experience with this vane pump?
shnitzel
Old 11-18-2010, 12:49 AM
eruzich is on a distinguished road
I just wanted to say thanks for the links..I will see what I can find out and get back to you.
Need Help!- Rotary Vane Engine-Mallory CGB Hobby Discussion 8 01-04-2011 08:22 AM
Problem- AV vane operated position sensors Appalachiatools General Electronics Discussion 2 04-18-2009 11:14 AM
Need Help!- Vane Position Sensors frankg521 General Electronics Discussion 14 07-31-2008 07:06 AM
5 Vane Impelar rpicker1 General Metal Working Machines 1 05-11-2004 08:23 AM
