Here's my machine so far. I still need to do up a proper table top and dust collection though. 4'x8'x8", belt drive xy, screw drive z. 2x2 steel tube table frame 8020 and steel angle gantry angle iron rails with v-bearings It works better than I had expected and I grin like a fool every time I use it! The vid shows it cutting a sign. The guitar is a project that I am doing on the machine currently.
__________________ DPRouter 4'x8'x8", Rockcliff Driver, 425oz. Nema23, 2HP, Belt drive xy, Acme z, 400ipm rapids, 120ipm safe cut |
| Hi, nice work. Can you tell us a bit more about the belt drive details ? I am in the design / build stage of a belt drive my self. Thanks
__________________ Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2 |
| SS |
| Thanks for the comments guys! I used 3:1 gear reduction from the stepper which then drives a pulley along a tightly stretched piece of 3/4 wide belt - works much like rack and pinion. The attached cad image shows my setup, sorry I don't have a photo at the moment.
| D.
I don't have photos, but here are a couple of cad images.
| darrinp, Your stated performance looks good to me. Some questions, if I may... I can't see any means of holding the Z-axis on the rails. Do you have some means to prevent the Z-axis lifting up off the rails? Secondly, do you need to grind/mill a v-shape on the top of the angle iron to match the v-shape of the truck wheels? It seems to have little contact with the angle iron rail. Finally, where does one get that aluminum extrusion stuff in Canada? Thanks, KOC62 |
#10
If you look closely at the pics, there are aluminum blocks attached to the underside of the 8020 cross members which hold another set of v-bearings against the lower edge of the angle iron. See the image below... As far as shaping the rails goes, I hand-ground them using a large whetstone, running it back and forth in long, smooth, uniform strokes, at a 45 degree angle. The bearings themselves seem to actually be work-hardening the surface somewhat, they're getting shiny like chrome now after some use. I know that it is not the ideal setup - I would much prefer blocks and rails - but it was pretty cheap to do and the performance is freakin' me out to be honest. I have machined aluminum on it and the performance is OKAY... a bit of vibration due to 8" travel on my z. If I raise the aluminum up so the head doesn't come down so much, the performance is better. I also have 20 years experience cnc machining aluminum on industrial equipment so my expectations are high. I built this machine for wood and plastics and so far I am a happy camper. If you are in the Toronto area, 8020 extrusion is available from IPEX Automation in Concord. It works out to roughly $11/foot plus $2/cut. Well worth it to let them cut it, all paired lengths are cut with a stop, so all the pieces matched perfectly. Their Cutoff saw is also built for this stuff, mine, not so much. They also carry a lot of other "fun" stuff. Depending on your budget, this is a place that could be fun for servos and stuff too. All industrial stuff, not so cheap.If you are near Toronto, pm me...
| Direct Drive Vs Belt Drive for a Mill/Drill Retrofit? | pfeist | General Metal Working Machines | 11 | 02-13-2012 02:12 AM |
| Newbie- Belt drive or direct drive? | rholliday | General Metal Working Machines | 2 | 02-16-2009 05:21 PM |
| Belt Drive | Jerry In Maine | Commercial CNC Wood Routers | 0 | 05-12-2008 11:50 AM |
| Need Sherline Belt & qestion on X2 Belt Drive? | Oldboy | Benchtop Machines | 12 | 03-06-2008 12:42 AM |
| X3 Belt Drive? | pzzamakr1980 | Benchtop Machines | 16 | 11-14-2007 10:15 PM |
