I need to cut some gears out of MDF on my CNC benchtop mill and i need help with speeds and feeds depth of cut etc. I am cutting MDF of 8mm thickness 5mm dia 2 flute tungsten carbide straight flute router bit My maximum spindle speed is 2150. Thanks in advance. |
| Your low spindle speed will be your limiting factor regards feed. I use G-wizard which you'll find here GWizard Install It's great for giving you a rough ball park figure to work from and this is what it says for MDF with that cutter and spindle speed. 100% cutter width: conventional cutting recommends climb if 50% Depth Feed 1-3mm = 1088mm/min 4mm = 895mm/min 5mm = 760mm/min 6mm = 718mm/min 7mm = 675mm/min 8mm = 630mm/min Hope this helps |
| How do you decide cutting speeds for cutting plexiglas? | angryManLT | Glass, Plastic and Stone | 3 | 05-04-2011 09:28 AM |
| Malaysia's Local Flame Cutting CNC, Plasma Cutting CNC Manufacturer : RobotshopCNC | MechanoSystems | Product Announcements & Manufacturer News | 0 | 01-25-2010 07:53 PM |
| Newbie- Newbie needs help! cutting acrylic, and double cutting? 3040 machine | stephaniehamer | Laser Engraving & Cutting Machines | 5 | 06-29-2009 03:37 PM |
| Can Watr jet cutting and laser cutting make endmills obsolete? | slashmaster | Benchtop Machines | 24 | 06-18-2009 04:07 PM |
| I need help about cutting heads which apply to apparel pattern cutting machine | sheepgrass | Mechanical Calculations/Engineering Design | 0 | 05-12-2006 01:09 PM |
