I have this board and I am trying to hook up a Blue screen z finder probe in mach 3. According to the info I have, pin 15 is supposed to be free. Problem is, there is no screw terminal for it. How am I supposed to access other pin in/outputs if there are no terminals??? |
| Get a little creative, Flip the board over and solder the wire directly to pad 15 of the DB25. Jeff...
__________________ Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish. |
| TheProCreator, You may need to add a pull up resistor from +5 volts to pin 15 on the DB25 4.7K should be ok. I am assuming you want to set the probe active low. Jeff...
| Here's the thread I'm following: http://www.cnczone.com/forums/mach_w...ification.html Nothing is mentioned about adding 5v for the probe lead, however he does set it at "Active Low" Let me see if I can get this to work. I will need to know how to solder up a resistor to the pin 15 lead if this doesn't work. Can you walk me through that? |
| Newbie- Driver board is not equipped with free pin outputs! | TheProCreator | Mach Software (ArtSoft software) | 0 | 11-14-2010 11:37 PM |
| I need 6 inputs, but my breakout board has only 5, how? | lucky021 | Canadian Club House | 7 | 06-13-2010 03:28 PM |
| plutp-P board encoder inputs | visky | LinuxCNC (formerly EMC2) | 2 | 04-23-2010 01:44 PM |
| Newbie- Stepper driver with Jog+ Jog- inputs | Zathras | Mach Software (ArtSoft software) | 13 | 06-22-2008 05:05 AM |
| resistor between bob and driver inputs? | Aiko | General Electronics Discussion | 6 | 06-25-2007 04:29 PM |
