Hello everyone, Just hooked up my g540 tonight to test it out. I hooked up 1 servo in a test. I downloaded the g540.xml file and verified that it IS loaded. I jumpered the estop and it does go from fault to power. When I do that, the servo makes kind of a high pitch sound and holds torque. The high pitch sound isn't very loud. It's pretty faint. ~~ should it make that sound? I ran a program in Mach 3 and I don't get any motor output. Is there anyway I can actually verify that Mach 3 actuall 'sees' the G540. My motor wiring to the g540 is correct, verified it several times according to Keling's site. edit: just to add to this, If I do the estop on the g540 should mach3 stop, or is that only if I do the on-screen estop within mach3? Cuz, I do the g540 stop and the program just keeps running. I did enable EPP in the bios as well. Thanks!!! Last edited by Rotax91; 11-12-2010 at 12:06 AM. |
| Is the charge pump switch enabled? If it is, and it comes out of fault, the gecko sees Mach You are clicking the Reset button on Mach, right? Is it green outline? If it is, it's believing it sees the gecko. After that, ports and pins |
| Thanks for responding to my post. Yes, the charge pump is enabled. I tried it both ways. And yes, I did click the Mach estop button and it had green around it. I did find something late last night. I check my DB25 cable and most of the top row of pins aren't connected at the other end. It utilized mostly the bottom row. Serial cable maybe? Perhaps this is my problem?? Thanks. |
Why would you even try anything else? Where did you get this cable and what was it called? It could be any kind of cable if you don't know what it is. A serial, a null modem cable, a cable that only has the pins a parallel printer uses or one of many special cables out there. Connectors alone don't make the cable... Hopefully you haven't damaged anything... |
| I didn't purposely try to make a non-working cable, work. The cable is a (M) DB25- (M) DB25. It's a cable I had around for years. There's no labeling on the cable. Not sure where I got it. Can you please post a link to a site that has the appropriate cable? Radio Shack appears to have a very limited selection. Thanks. |
| One obvious cable is Then there is: 6ft DB25 M/M Cable - Cables To Go or 25 pin Parallel DB25 DB-25 Printer Cable Male M/M 10 Ft - eBay (item 170348038827 end time Nov-14-10 22:56:58 PST) |
| Ebay item 300490904323 should work PMDX sells a cable specifically for this and breakout boxes and cnc stuff in general. He has a cable here.. PMDX.COM - Products for CNC and motion control applications Actually most parallel port extension cables should work. Here is a bunch of standard cable wiring diagram.. http://www.jspayne.com/io/schematics.html I have sometimes had to use a cable with male and female connectors and then use a 25 pin to pin gender changer on one end. Good luck.. |
| Thanks guys!! I appreciate the effort. I will pick the one that can get it to me the fastest. I don't think I would have hurt anything since the port is pretty much made up of I/O and not voltage transmission. Looking at the pinout in the g540 manual, looks like the step/direction lines are in 1-9 which on the cable I was using, are not connected. When the servo is at idle/ unit is powered on. Do the steppers make a high frequency noise? I describe it like the noise that old tube televisions made. Also, the shaft is tight. Can't turn it by hand when power is applied. Normal? Thanks again. |
Just FYI.... And the noise steppers make at idle is usually from the drivers. I have not heard the G540 so I can't say what is normal... Garry |
#11
| Hi again. Well I got it going. I found an old cable in storage that came over on the mayflower. It was M/F so I had to use a straight thru gender changer. I ran a program and all is good. That being said, I still hear that high frequency noise. The noise is coming from the stepper itself, NOT the g540. The 540 is fine. I can only hear it when the stepper is still. Is this normal for the motor when power is applied to it. It's not a mechanical noise (ie bad bearing, etc..) this is an high frequency electrical noise. Thanks. edit: I emailed John @ Keling and he thinks I need to tune the motor(s). Perhaps that's all it is? Last edited by Rotax91; 11-12-2010 at 01:57 PM. |
| G540 Spindle Control Working | whitehedr | Benchtop Machines | 9 | 09-21-2010 08:19 PM |
| anyone have a working emc g540 configuration? | coltz | Gecko Drives | 4 | 10-26-2009 02:06 AM |
| Need Help!- G540 x-axis slow jog stops working after a minute | Waldermac | Benchtop Machines | 3 | 07-11-2009 11:50 PM |
| Anyone get the G540 working? | Fixittt | Gecko Drives | 10 | 05-08-2009 09:12 AM |
| G540 input not working? | stoneyreef | Gecko Drives | 1 | 05-08-2009 01:52 AM |
