Old 11-10-2010, 06:47 PM
Raba is on a distinguished road
5 X 10 router Belt Style
Hello everyone. Im planning on staring to build a 5 x 10 CNC router. For the X and Y axis Im planning to use belts. What type of belts do you guys use (Xl, L HTD, etc.) and what width? Also does any one know a good supllier, I live in the Midwest.
Thanks in advance.
Old 11-10-2010, 07:09 PM
harryn is on a distinguished road
Hi, There is a lot of good information on belts on the brecoflex web site. The amount of information on belts and the application is just astounding. From there, you can make quite an informed decision.
I am also working (slowly) on a belt drive router, so if you search around on the threads I have posted in, there might be some useful information in that as well.
I was surprised at just how robust of belts are needed on a large router. The forces can be considerable.
Supporting RanaTeckk.com and their Dashboard for MS Project promo code WRLNT-2
Old 11-10-2010, 10:23 PM
Thanks harryn. I checked it out and I might order from them. What did you end up getting?
I also have one more question. Has anyone tried slaving servo motors, I would like to use two servos to drive mine X axis.
Old 11-11-2010, 09:56 AM
Hi, my project is still funds limited, so actual purchases have been slow, including the belt and pulleys.
My latest belt calculations, guesses and info are in this thread. I had been hoping more people would comment on them, but so far, not many takers.
http://www.cnczone.com/forums/mechan...ml?#post848610
So, far, I am leaning toward 150ATL10 (6 in wide, ATL 10 belt with steel wires). I originally used tooth strength to calculate, which indicated that 25mm wide belt would be fine, but then I was reminded about stretch, and that drove a wider belt selection. In the end, it all comes down to investment vs tolerances, regardless of the drive approach.
Old 11-11-2010, 04:16 PM
Hyrum R is on a distinguished road
I built the belt-drive solsylva table a while back (with several modifications, I might add.) Belts are wonderful for fast jog speeds and light cutting, but there's just too much stretch and bounce to do any heavy cutting at a very fast speed. I can jog at over 800ipm all day long, but I'm lucky to be able to cut 1/4" deep at 75 ipm.
If I had it to do over again (and I am going to be....once I get enough $$$ together ), I'd go with rack & pinion. The components are close to the same price, but it seems to me, you'd get a much more rigid machine.
Old 11-11-2010, 05:24 PM
Hi, thanks for that info. Could I ask what size and type of belts you used ? Most people seem to use 1/2 to 1 in wide belts, while my calculations indicate something more like 6 in wide is needed for serious work.
Hyrum R, 75 ipm does sound too slow for machine that size. What belt width did you use? And harryn, Brecoflex only has 100mm of that particular belt, where are you planning to get the belt 6in wide?
Old 11-11-2010, 05:39 PM
Figures. I was hoping to just use one belt for my Y axis 150 mm wide. I guess I need to either go to AT for 150mm, or 2 belts x 75 - 100 wide. I was really hoping to eliminate a pulley set by going to one wide belt.
Old 11-11-2010, 06:24 PM
The belts on my machine are 1" (correction: 3/4") wide. If I was cutting foam, I'd let it rip at 500ipm. Anything with much force really causes trouble, though.
Old 11-11-2010, 07:00 PM
Hyrum R, I checked out your build thread and it looks like you have fixed belt design for X and moving belt for Y. Which of the axis causes more trouble?
  #11   Ban this user!
Old 11-11-2010, 07:04 PM
harryn, I looked at your build thread and it appears you want to cut aluminum as well? Im building my router to cut mostly plywood and MDF. Also my gantry will not be moving up/down, so I guess my belts don't have to be that wide?
  #12   Ban this user!
Old 11-11-2010, 07:18 PM
If anything, the Y axis seems to have a little more trouble than the X. It's not too much of a problem as long as you know the limitations of the machine. I have a lot of ideas going through my head right now about a bigger better machine. (Don't we all. )
Tags
belt drive
setting machine to go home on a gantry style router chipmassa Mach Mill 0 07-18-2009 03:06 PM
New Machine Build- 8020 style aluminum cnc router rwaudio DIY-CNC Router Table Machines 11 06-05-2008 06:22 PM
CNC router using kee-klamp style clamps? octothorp DIY-CNC Router Table Machines 34 10-17-2006 08:09 PM
RFQ Z Axis Gantry style router Jan-Roger Employment Opportunity 2 07-31-2006 10:24 AM
Gibbs and a gantry style router bgolash GibbsCAM 1 12-18-2004 12:24 AM
