Old 11-08-2010, 03:10 PM
bandtank is on a distinguished road
trying to pick a router
I am almost done with my machine, but I can't figure out which router to use. I bought a 2hp wood router, but I've been lead to believe it is not a good choice if I want to work with aluminum. I am most interested in cutting wood, but I do want to work with aluminum up to 1/2" if possible as well as certain types of plastic.
I've searched this forum for the last hour and found nothing. I either didn't enter the right search strings or I just haven't found an answer to my question. I have also been doing research about variable vs fixed speed routers, but none of them seem to be what I want. Ideally I would like to find a router that can be geared down (someone told me this exists, but I can't find one).
Here is a video of my machine. I tested it last night and it is accurate to about 0.0002" (with no load). I was very surprised!
YouTube - CNC Machine - new bearings, faster rapids, executing G codes
Any advice would be appreciated.
Old 11-08-2010, 10:53 PM
Dorsal is on a distinguished road
If you want to start running the machine, mount the router you have and start cutting materials.
If you want to spend a lot of money so you can brag you spent a lot of money, go finance the most expensive high-speed spindle you've ever heard of.
If you want to machine 1/2" thick aluminum stock, go buy a mill.
Old 11-08-2010, 11:45 PM
I apologize if I am reading this wrong, but your post seems pretty rude and unnecessary.
Old 11-08-2010, 11:47 PM
dertsap's Avatar
Gold Member
dertsap is on a distinguished road
good looking machine and nicely done
the problem is that it won't be solid enough for any heavy metal machining , but it doesn't mean that you can't do any ally . wood routers work ok as long as you take passes .05' or less , and looking at the design of your machine I'd imagine that's the max you'd be able to push it on aluminum anyhow .
.05" at 50-100 ipm will remove material quite rapidly as long as you are strategic in your toolpathing . conventional milling will probably produce the best results
. I've managed to cut mild steel at 120 imp with my wood router as a test and it cut it pretty easily , i just wouldn't do it on a regular basis ,
since you've got the router then you may as well throw it on and see what you can do with it
I have to agree somewhat with the last comment and that is if you plan to machine lots of metal then your best option would be to have a mill , or to build a beast that can handle the punishment
A poet knows no boundary yet he is bound to the boundaries of ones own mind !! http://cnctoybox.org
Old 11-09-2010, 12:56 AM
Thanks for your advice. I realize the limitations since it is built out of aluminum instead of something stronger, but I was just hoping to do at least basic cuts in up to 1/2" aluminum. I can't afford a mill, so that's why I was hoping to get some ideas from the community about how to make my current solution meet all of my needs if possible. As I said in the original post, I just don't know what router to get or if a spindle is the right choice. I'd give you all the relevant information if I could, but I'm not even sure how to make this decision. The more research I do the more I realize that there are a lot of unknown variables that I need to solve. I also don't want to mount my current router as I just purchased it and it is still in brand new condition. I could return it if it isn't going to meet my needs, but if I mount it I am stuck with it.
I know for sure I want to work with wood, plastic, and to make PCBs. Optionally, I would love to be able to handle some amount of metal, even if it isn't anything complicated. I just want to have the option if it can be reasonably included in whatever router/spindle I end up using. I've seen the Paul Jones spindle for PCB manufacturing, but that obviously won't work for other materials and projects.
I hope this clears things up a little. Thanks again.
Old 11-09-2010, 10:54 AM
Sorry, I forgot to include the flowers and poetry, to soothe your mind and ease you into the truth. I leave that part for others to complete.
Old 11-09-2010, 11:12 AM
You should be ashamed of your attitude. Please stop posting in my thread if you have nothing to contribute.
Old 11-09-2010, 11:20 AM
You posted a serious question, I thought you wanted a serious answer. Sorry, my mistake.
Old 11-09-2010, 11:30 AM
You're right. This seems completely serious and not at all condescending or sarcastic.
Also, thanks for explaining to me why my idea won't work or is unreasonable. You really cleared things up.
I've seen plenty of people on these boards cutting aluminum on machines made out of MDF or aluminum without high cost spindles. I'm obviously a novice so acting superior is lame when I came here for advice and help. I'd appreciate it if you could stop derailing my thread.
Old 11-09-2010, 12:38 PM
DonFrambach is on a distinguished road
I'm certainly no expert but I've been down the path you're about to start and I can share my experiences with you.
I have an old ShopBot PRT which works great for cutting wood. I tried to cut aluminum and found two problems. The first was that a wood router spun the bits too fast which was easily solved by using a Sherline spindle. The second problem was that I got lots of chatter because the moving gantry design paticularly of my old style ShopBot was not particularly rigid. You can reduce cutting forces and chatter by taking very light cuts.
Interestingly, the Sherline spindle works great for cutting plastics because I was able to cut the plastic at lower temperatures with slower cut speeds.
Hope this helps.
Don
BTW I'm making a small fixed gantry router that I hope will be able to cut fine details in small aluminum parts (using bits 1/8" and smaller). I've tried to make it as rigid as possible to reduce chatter.http://www.cnczone.com/forums/diy-cn...ter_build.html
  #11   Ban this user!
Old 11-09-2010, 01:29 PM
wcarrothers1 is on a distinguished road
Bit temp plays a part with alum as well. routers becides spinning the bits faster then perhaps you would want the motor also self heats the bit so it's motor heat + cutting heat can result in gummy aluminum cuts and broken bits.
when I cut aluminum (sheet) material like .040 thick on my router I use onstrud single flute cutters and run at pretty fast speeds. The cutters make most of the difference though. (course I also have a VFD spindle which does not heat bits like router motors do and can also run slower RPM's then my router could)..
also don't forget cutting oil could be of some help as well but hard to use that and not make a mess of a nice MDF table
b.
b.
  #12   Ban this user!
Old 11-09-2010, 02:38 PM
Thanks for the information guys. I did some more research after you both gave me some things to think about and I'm wondering if the Hitachi KM12VC will work for my application. I've noticed quiet a few people using it to cut aluminum as well as wood, but I'm confused about how they are putting smaller bits in it when it can only accept .25" and .5" shanks. How would I put a 1/8" or smaller bit in it? I know this is a silly question, but I can't find an answer.
Router using old PCB pick & place machine celephicus Open Source CNC Machine Designs 2 12-09-2010 10:02 PM
pick gaurd corrie Musical Instrument Design & Construction 1 08-12-2010 06:00 PM
SMD pick and place ciccio Printing, Scanners, Vinyl cutting and Plotters 194 01-19-2010 12:34 AM
Anyone SC or NC need a Pick & Place? Al_The_Man CNCzone Club House 0 01-18-2010 02:46 PM
pick off on citizen f12 cseely CNC Swiss Screw Machines 2 01-09-2008 11:13 AM
