Old 11-05-2010, 07:11 PM
Rene Nuñez Paz is on a distinguished road
Sources for 1/8" Plywood or MDF in Florida, USA
Please, I need to know where is possible to buy 1/8" MDF or Plywood sheets
in Miami or nearest as possible in Florida, USA
Thanks in advance for your help
Regards
Rene
Old 11-05-2010, 09:12 PM
CarveOne is on a distinguished road
If you do a Google search on Florida Hobby Shops you will find R/C model shops that sell Midwest brand birch aircraft grade plywood in various sizes and thickness. Hobby Super Store is in Plantation, Florida. The link goes to their birch plywood selection.
CarveOne
CarveOne
Resistance is not futile. It is voltage divided by current (R=V/I).
Old 11-05-2010, 09:34 PM
PropNut's Avatar
PropNut is on a distinguished road
Contact your local custom cabinet shop, tell them what you need and you may be able to buy it from them or have them get it for you for a surcharge. Plywood wholesalers sell 1/8" plywood for many uses but it is most often called, and used for, door skin.
My supplier up here in Michigan is VictorBarnes inc, wholesalers do not sell to the public but cabinet shops are usually pretty good about getting things for people if they do not have to go too far out of their way. You might also check with door manufacturers in your area as they may have scraps the size you want or they too might pass a sheet or two through the door to you for a surcharge.
Hope this helped,
David
Old 11-05-2010, 11:17 PM
Hi, Carveone and Propnut, I appreciate your help and suggestions.
Thanks very much.
Regards
Rene
Need A Quote- 3" Baltic Birch plywood disks gmed Employment Opportunity 19 05-12-2008 09:17 PM
80W Laser 3/4" Plywood cutting speed coleclan Laser Engraving & Cutting Machines 6 12-18-2007 12:49 PM
40 watts not enough to cut 1/32" plywood????? Mrebeiro70 Laser Engraving & Cutting Machines 10 10-24-2007 09:23 PM
RFQ: pieces of 0.5" baltic birch plywood in LA gmed Employment Opportunity 2 09-03-2007 04:27 PM
Water Pressure to Cut 1/8" plywood? J Solinger CNC Plasma and Waterjet Machines 0 06-05-2005 08:54 PM
