Old 11-03-2010, 09:54 AM
DonFrambach is on a distinguished road
"Pro-Precise" Spindle from IMService
For $1,149 you can buy an 800 watt 120 volt spindle, VFD drive, computer interface, and cooling system from IMService. I like the idea of 120 volts and (presumably) a working system right out of the box with US support. For now this is out of my budget. Any comments?
IMService
Name:	Pro-Precise Spindle.jpg‎
Old 11-03-2010, 10:41 AM
ger21's Avatar
You can buy the same spindle and VFD by themselves for about $400 or less directly from China via Ebay.
"low end" HF Spindle or "high end" router for about $1000? biomed_eng DIY-CNC Router Table Machines 14 01-06-2012 12:15 AM
How to "offset" Double sided PCB if I don't have abolute "home" on my CNC ? Calico PCB milling 11 07-12-2011 06:02 AM
Newbie- Feedrate for 0.02" precise bit on ebony ? rdpdo WoodWorking 2 05-15-2010 10:29 AM
Need Help!- "motor steps per resolution" and "driver microstepping" settings margni74 LinuxCNC (formerly EMC2) 9 10-24-2009 02:33 AM
"J" head type "millport"(tiwan,1980) clutch marksbug Bridgeport and Hardinge Mills 1 08-17-2009 10:48 AM
