Old 11-02-2010, 12:25 PM
kolias is on a distinguished road
High Cycle Linear Bearings
I’m designing my second CNC Router and I wonder if anyone has built one using the 8020 “High Cycle Double or Single Flange Linear Bearings”
I just got a sample (Single Flange) to experiment with it and feels just right for a CNC
Your ideas?
Name:	8020 Sample Bearing1.JPG‎
ID:	118206   Click image for larger version
Name:	8020 Sample Bearing2.JPG‎
Old 11-02-2010, 07:24 PM
Gold Member
RomanLini is on a distinguished road
What's the slider material?
If it's just a plain plastic they will probably be only good for low speeds.
Old 11-02-2010, 07:36 PM
Its called UHMW and I know about this stuff, very good but seems expensive.
For 6 bearings (enough for 3 axis machine) about CAD$500.00
Old 11-02-2010, 09:26 PM
ger21's Avatar
Not a good choice. You'll find they bind rather easily.
There is a machine on here using those, though.
http://www.cnczone.com/forums/diy-cn..._bearings.html
Old 11-02-2010, 09:28 PM
svanommen's Avatar
svanommen is on a distinguished road
I too considered those linear bearings and as you've pointed out they get pretty expensive pretty quick.
To me it seems quite counter productive for the following reasons: Cost - CNCrouter parts bearing blocks are not expensive at all.
Wear - the plastic can only wear to lubricate itself. As we all know accuracy is key. So once the plastic bearings have broken in, it's a steady decline of accuracy over use.
... I had a 3rd but the above 2 are more than enough for me.
If you do go this route I would be curious to hear how it runs though. =)
Old 11-02-2010, 10:20 PM
mlabruyere's Avatar
mlabruyere is on a distinguished road
If you have a shop that sells 80/20 near you go there and ask for a demo table setup with the bearings. You'll find that it takes little lateral force to cause it to bind. The small sample you have there won't alow you to place any real force on the bearing material. They are great for creating movable members in a shop but not really great for CNC work. I looked at these too....
I did buy the bearings from cncrouterparts for my first machine. My second one is getting "real" linear rails and bearing trucks.
Old 11-02-2010, 11:19 PM
Benonymous's Avatar
Benonymous is on a distinguished road
I can see the attraction, these are a purpose made part to go with the extrusion. However, I agree with the other posters that these will wear quickly. You can do much better for the money
Old 11-02-2010, 11:24 PM
Thank you Ger21 for the link, very interesting
Old 11-03-2010, 02:43 AM
I’m afraid that I will have to disagree with you guys about the UHMW slides.
As you can see from the attached photos, I made my own UHMW slides for my present CNC machine and after 1 year of operation I can’t say enough good words for them. Although the way I installed them was very primitive because it started as an experiment, they turned out to work very well, silently and very efficiently.
I bought the UHMW material from LeeValley.com and cut them with my table saw or scroll saw for the small pieces and it was fun to work with them. If the 8020 slides were not as expensive I would definitely have gone with them.
I’m not saying they are the best but to my opinion they are an excellent alternative
Name:	7 FINAL X Axis Slides Design.JPG‎
ID:	118245   Click image for larger version
Name:	7A FINAL Y Axis Slides Design.JPG‎
ID:	118246   Click image for larger version
Name:	7B FINAL Z Axis Slides Design.JPG‎
Old 11-04-2010, 02:22 AM
Gold Member
There's plenty of better plastic choices than UHMWPE for that job. Delrin would be a big step up being slipperier harder and higher melt temperatures. There are also plenty of specialty bearing plastics that have lube etc built in and are not that much dearer than UHMW.
Having said that, I do like plastic bearings, my machine uses IGUS brand Drylin bearings, they are excellent as a 3 part composite with teflon for slip, plastic as a binder and a high stiffness component for anti-creep. They sell them as sliders too to go direct onto round rails either supported or non supported.
Kolias- Nice setup!
Just IN- High Precision, High Speed Bearings mikeyg Product Announcements & Manufacturer News 0 09-07-2009 07:06 PM
Need Help!- Seriously need help with linear bearings! xadon Want To Buy...Need help! 5 04-14-2008 10:05 PM
Linear Bearings teenrocketnerd DIY-CNC Router Table Machines 3 06-25-2007 05:05 PM
skate bearings versus linear bearings paul langwade Linear and Rotary Motion 7 05-29-2006 10:06 AM
Need help on linear bearings bbergami DIY-CNC Router Table Machines 11 05-25-2004 06:04 PM
