| Hi, Need some help please! I have two steppers that drive my X Axis; I would like to wire them up to my controller card so that they are both on separate outputs. I have wired the second stepper up and made it axis A and salved it off of , so far and it moves in both directions fine. The problem is when I home the machine it’s as if when it gets to X that both motors are trying to go in different directions. The controller card is a basic C10 Breakout card. Any ideas? I have tried to attach the Mach3 machine set up with no joy, if anyone is keen to give me some advice that would be much appreciated. Cheers D |
| I've answered this 3 times this week. ![]() If you have only one home switch, in general config, Check the box labeled "Home Slave with Master Axis". If both the master and slave have their own switches, then you probably need to reverse the homing direction of the one axis in Config>Homing/Limits. Use the Home Neg. column.
| Hi I tried the A - Axis home negitive with no result. steppers tried to go in differant directions (well it seems like it) I also tried to find the "home slave with master axis" undar genral config with no joy what so ever the version of Mach 3 i have is 1.83.027 im guessing that feature is in a more recent version? You are correct i only have one home switch on the X-Axis. more help welcome Cheers and thanks D |
| With that old version of Mach3 you'll need two switches, one on each side.
| If you can, I'd recommend adding a home switch so you have one on both sides of the gantry. Then you'll square the gantry when you home it. I know I've had times when I stalled one x motor but not the other and the gantry was definitely not square. With dual home switches I could fix that very quickly.
__________________ CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html Last edited by jsheerin; 11-03-2010 at 11:14 AM. Reason: typo |
| Need Help!- Dual Y Axis Slave A Axis Homing Problems | guy2b1 | Calibration & Measurement | 4 | 03-03-2012 04:06 PM |
| Problem with X and A slave axis | deemon328 | Rockcliff Machine | 6 | 09-02-2010 01:00 PM |
| Need Help!- How to assign 5th & 6th Axis to Slave when Pin 2-9 already used in 4 Axis for Mach3 | guy2b1 | General Electronics Discussion | 8 | 10-29-2009 08:09 AM |
| Need Help!- Slave axis problem | Curtis Erpeldin | DIY-CNC Router Table Machines | 5 | 07-30-2008 02:57 AM |
| problem with my z axis on mach3 | thesaent14 | Machines running Mach Software | 18 | 04-06-2007 05:28 PM |
