Old 10-27-2010, 04:40 PM
kolias is on a distinguished road
Driver Triggered?
I have been away from my home build CNCrouter for more than a year but now I’m back. Unfortunately the HD on my laptop which runs the CNC crashed and had to re install XP but I lost my config file for the CNC and now I have to re configure the machine.
I run Mach3 and all seem to be ok now but I get the message “Driver Watchdog Triggered” and I don’t know what means.
Any ideas?
Old 10-27-2010, 05:19 PM
GaryCorlew's Avatar
GaryCorlew is on a distinguished road
It usually means an abnormal condition, If you like you can uncheck it in general config, its over on the right side about a third the way down
Old 10-27-2010, 05:29 PM
hemsworthlad is on a distinguished road
This is not uncommon and it's nothing wrong with your machine, just seems to be a quirky thing mach does know and again for no obvious reason.
Just turn it off in general config.
Old 10-27-2010, 06:22 PM
Now I got it, thanks to both
limit switch triggered issue 15mgtar Mach Software (ArtSoft software) 6 10-19-2009 03:25 AM
Driver Watchdog Triggered???? rweatherly Mach Mill 1 07-01-2008 03:31 PM
Limit Switch Triggered! IS NOT!! Mr.Chips Mach Software (ArtSoft software) 24 12-26-2007 05:44 AM
Limit Switch Triggered?? H2ODiver Mach Mill 7 02-22-2007 11:48 AM
Gecko triggered E-stop circuit? sol Gecko Drives 20 11-27-2006 08:58 AM
