Old 10-24-2010, 10:52 AM
vpl vpl is offline
vpl is on a distinguished road
THK SR20 linear guide question
Hi All,
I'm on the fence here with using a set of THK SR20 linear guides (for x axis) that I can buy on ebay or go with the .250x4 1018 flat bar and skate bearings with the appropriate sleds. So I want a 4 x 8 usable cutting area and have it be about as heavy duty as a mechmate. So my question is are THK SR20 linear guides a good option and are they stout enough for this application. A used set is a few hundred dollars more than setting up the skate bearing affair. I would assume more accurate and less hassle in the long run......?? 20mm wide doesn't seem too sturdy but I don't have any practical experience in this area...what do you think. For the length I want 2 rails will have to be mated.....
Yes I looked up the load ratings and all I can say is way too much info for a noob. If someone who knows would just say, "they are too small and you need a "XXXXX" width that would be great." Or maybe, "that's what Ive been using and they are fine...."
Please help I want to start my build and this is my biggest stumbling block.
I wanna buy some steel and start building....
Thanks People,
Vince
Old 10-24-2010, 11:04 AM
ger21's Avatar
If price isn't an issue, I'd go with the THK's in a minute. They can carry far more loads than anything you'll throw at them. Not even anywhere close to the same leage as skate bearings.
Old 10-24-2010, 02:30 PM
vpl vpl is offline
I figured.....
Thanks Gerry-
I figured this was the case, so specifically are the THK SR20 linear guides good for the build I'm after? I know they come in different widths and different load capacities. I hate to keep asking but your answer was fairly general. As far as $ goes there is a set that may be affordable. After pricing out a bunch of skate stuff the linear rails are more but not entirely too much. I really like "carveone's" finished unit. Its a very enticing design, and not too spendy. His handy work makes a nice finish and looks very pro. I would like to do something similar but use the THKs and tuck them under the table to keep them away from chips and what not. So what do you think-are 20mm THKs specifically more stout that skate bearings on .250" cold rolled...even for a 8' + travel.....
Thanks again Gerry I'm sure these questions get monotonous. However your answers are very appreciated and anticipated.
Vince
Old 10-24-2010, 05:59 PM
ger21's Avatar
20mm THK's can typically carry several thousand pounds. However, the surface they are mounted to is critical to achieve that. You need a steel or aluminum surface to mount them too, and the rails will only be as flat and straight as that surface. If the mounting surface can flex or bend when force is applied to the rails, then the rails will bend as well.
Odds are that you won't use 25% of their capability, but again, they must be used correctly.
Old 10-24-2010, 06:18 PM
mactec54 is on a distinguished road
vpl
What is the price on Ebay, & only buy them if they are new,PM me with what you want & I can most likely get you a better deal, for new rails & bearings
Mactec54
Tags
linear, rails, thk
Just IN- PBC Linear Provides Upgraded Linear Guide Parts to Bay Area Transit Pacific Bearing Product Announcements & Manufacturer News 0 08-10-2010 04:42 PM
How much for HM-145X with linear guide??? diylife.com.tw Product Announcements & Manufacturer News 0 07-28-2010 04:27 PM
Linear guide resistance... SatanKlawz DIY-CNC Router Table Machines 16 06-06-2010 12:16 AM
Need Help!- Star SR20 Macro question jrob69 Rams Software 2 10-18-2009 07:26 PM
Support for linear guide wile_e Mechanical Calculations/Engineering Design 7 01-29-2005 05:30 PM
