Old 10-23-2010, 06:27 AM
Rajpage is on a distinguished road
My home made cnc - Need a good spindle?
Hi there, this is my first post here. Hope i'm in the right section, but here goes!
I've just built this!...
(You may have to open these in a new window...)
6mm Aluminium base, 30mm thick HDPE blocks, bla bla bla... similar to the lumenlab micRos.
I want to use it to mill various things, but mainly, aluminium, acrylic, HDPE, and most importantly being an electronics student, PCBs!!!
The spindle you see is a old old old Dremel moto-flex I got off ebay for £30. It's a 110W motor fixed to 25,000 RPM. No good for cutting acrylic?
Thing is it's also very noisy and not variable. I'm a student and this sits in my bedroom screaming away, while my flat mates find it cool at the moment, I know it'll soon start getting on their nerves. I'm tempted to go for a Dremel Fortiflex, this any good? Nearly went and got a Kress 1050 FSE-1 but the achine won't support that weight too well.
In terms of some kind of coolant/lubricant for cutting aluminium, I've been using WD-40. Seems to work well but stinks out the room.
I cant use lots of liquid either because it'll end up all over the place, was thinking about using a water mist?
I need something similar to a Shopvac. living in the UK, I cant find any of those. Any small vacuum cleaner will do. Willing to try make one of those cyclone dust extractors.
So in summary, is anyone able to recommend:
A good spindle (not too heavy/noisy/under £250/variable speed)
A non messy, non toxic coolant/lubricant
A small quiet wet/dry workshop vaccume
Thanks all [=.
Old 10-23-2010, 08:08 AM
hemsworthlad is on a distinguished road
Re- spindle, think your going to struggle to find a quite and light weight spindle with out building your own. I have the super quiet water cooled spindle but it's very heavy.
Depending on your access to equipment (lathe etc) then I would think about making your own using a ER collet spindle shaft and RC DC motor, there are few post's kicking around who have done the same.
Re- cooling, Air is your best bet for cooling without the fumes, I only cut ali with my machine and use air to do most of the cooling and chip clearing. Obviuosly then you'll have the noise of a compressor but there are some really quite ones about if you look. Using a mister can be even more fumey than just squirting WD etc.?
Where abouts in the country are you located, if you go the building your own route I have a lathe and maybe could help.?
Old 10-23-2010, 08:30 AM
draughted's Avatar
draughted is on a distinguished road
i like and have purchased the taig spindle with ER16 collets.
its just a matter of powering it now. it has a 10k rpm limit so it will be making chips not dust
Old 10-23-2010, 08:42 AM
Sounds like an option. I travel between London and Bristol a lot but that's about it. I'd rather just buy something than make it. I'm coming close to the end of my budget for where I could have bought a ready made machine and spindle from lumenlab. At the moment it's not the most stable thing because it's all been hand cut/drilled. It starts to vibrate very easily without lubricant and make a mess of things.
I've just been down the hardware store and have picked up some click and seal pot things to make a cyclone vacuum. It seems to be working. Maybe that could be used as air cooling? Is it as effective when air is being pulled in from around the bit?
The tiag spindle looks good, but I'd prefer something a bit more directly driven, I suppose the reason for the separate motor to spindle drives are to reduce vibration? I don't have much space on the Z-Axis, the spindle you see in the picture has a total diameter of 18mm. The machine was designed so it could support dremel or proxxon type tools.
Are the proxxon tools any good?
Old 10-23-2010, 08:53 AM
No you need multi directed air blast's using flexible nozzles.
Old 10-23-2010, 10:43 AM
ger21's Avatar
What about an 800 watt Chinese spindle from Ebay?
Old 10-23-2010, 01:45 PM
Do you mean the water cooled ones? I don't want to have to get a separate supply and water pump. The electricity bill on a student budget also limits me >.<.
I've been looking around, and it seems the Dremel Fortiflex is my best option. For what I'll use the machine for, 300W is more than enough. I believe there are larger hand pieces available that can hold 1/4 inch bits.
A bunch of people on youtube seem to get pretty decent tolerance on PCBs with Dremel tools.
Old 10-23-2010, 04:16 PM
ger21's Avatar
No, the smaller ones are air cooled.
Old 10-23-2010, 04:28 PM
Could you link me one?
Old 10-23-2010, 04:35 PM
ger21's Avatar
0.8KW AIR-COOLE MOTOR SPINDLE ENGRAVING MILLING GRIND - eBay (item 390218219614 end time Nov-10-10 05:42:03 PST)
  #11   Ban this user!
Old 10-23-2010, 04:51 PM
Cool, looks like possibility. Any idea how much one would weigh?
  #12   Ban this user!
Old 10-24-2010, 08:00 PM
jsheerin's Avatar
jsheerin is on a distinguished road
Don't forget you'll need a vfd to run one of these - extra cost.
CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
Home made ATC pstockley General Metal Working Machines 21 11-09-2009 04:12 PM
Hard drive servo spindle are any good for home made lathe? patriciooholegu Servo Motors and Drives 5 12-08-2007 09:48 AM
Home made EDM RFERG43 CNC Plasma and Waterjet Machines 18 08-29-2007 06:18 AM
Home Made internal spindle stop! widgitmaster Mini Lathe 7 06-15-2006 08:14 PM
Home made CNC mill (and some products made by it) gcamlibel DIY-CNC Router Table Machines 23 04-05-2004 05:54 PM
