| I've explained this a couple of times, search for this topic. Basically, the easiest way is to get a relay with a coil voltage that matches the power supply for your Gecko. Wire it up the way the Gecko manual describes. Wire the contacts of the relay to the hot wire (typically black) going between the outlet and the router. The neutral (typically white) and ground (typically green) wires are through connected from router to outlet. You could just purchase a 10' 14 guage extension cord and remove the outer insulation in the middle, cut the black wire and connect the two ends to the relay contacts. One relay coil connection is to the power supply +, the other is to the output pin on the Gecko. Set up the output in the Mach configuration screens, and then the G codes for turning the motor on and off will work. |
| mach3 spindle control on nm-200 | urbanimports02 | Novakon Systems | 2 | 01-19-2010 09:33 AM |
| Control Software other then Mach3. | propmod | General CNC (Mill and Lathe) Control Software (NC) | 8 | 03-17-2009 12:36 PM |
| VSD-A Spindle control in MACH3? | mkuivamaki | Granite Devices | 8 | 09-08-2008 02:09 PM |
| Router Speed Control + Mach3 + Breakout Board | Dingo745 | General Electronics Discussion | 7 | 06-19-2007 08:58 PM |
| BP CNC S1 Speed control with Mach3? | Jonne | Bridgeport and Hardinge Mills | 3 | 06-18-2007 02:31 PM |
