Old 10-19-2010, 08:48 PM
nate89 is on a distinguished road
Second Attempt at a CNC router...
Hey guys, this is my second attempt at building a CNC router and I was wondering if you guys could check out my design and make suggestions. I don't have a big budget (<100). I already have all the building materials, but if there is something that could make my life easier during construction, please let me know. I only have a 15"x20" that my router has to fit in. I also plan on making an enclosure for it, so obviously my machine has to be smaller than 15"x20".
Here is the sketchup model:
Simple Aluminum CNC by Nathan - Google 3D Warehouse
And an exploded view:
Aluminum CNC Exploded View by Nathan - Google 3D Warehouse
and a link to my blog where I plan on doing a full build log. You can also see my first attempt.
Old 10-19-2010, 10:50 PM
The Z axis will probably be shorter than in the CAD. I'm thinking 3-4" of travel instead of the 6" i have modeled. Other than that, everything is 1" square aluminum that will be brazed together except for some pieces that will need to be replaced/adjusted as things wear. The primary materials being cut will be foam, plexiglass, and the occasional aluminum/copper/brass. I'm really hoping to get this thing up and running so I can start machining pieces for a rep rap 3d printer and my foundry. I will be able to make anything hahaha (j/k)
Old 10-20-2010, 11:50 AM
jsheerin's Avatar
jsheerin is on a distinguished road
It's tough to tell exactly how you have the y axis being driven from the view you posted, but if you can find a way to box in the gantry legs and the y axis beam or just connect the two beams in each of these sections together so they look more like an I beam, that will give you a much stiffer structure with minimal additional material. For cutting foam it wouldn't matter. For cutting metal, it will be important.
CNC mill build thread: http://www.cnczone.com/forums/vertical_mill_lathe_project_log/110305-gantry_mill.html
First attempt at CNC router alt.don CNC Wood Router Project Log 12 10-09-2009 12:25 PM
first attempt at building a CNC router Wood.worker DIY-CNC Router Table Machines 8 10-26-2007 03:02 PM
First attempt aluminum cnc router rwaudio DIY-CNC Router Table Machines 2 10-12-2007 09:40 AM
My attempt at Joe's router DayneInfo Joes CNC Model 2006 58 01-29-2007 08:18 AM
My second attempt at a router raiven DIY-CNC Router Table Machines 28 06-07-2006 11:25 AM
